how activated seat belt warning light?
bl4ckclio
Post by bl4ckclio »
as topic
peugeot 406 2.0 16v
look at speedo clocks, there is seat belt warning light but blank off bulb.
I try to fill the bulb, but the light won't illuminated when the belt released from pretensioner.
anyone knows how to make the light illuminate when the seat belt released?
thanks.
Jay.
Re: how activated seat belt warning light?
Hello,.
you might need differnt seat belt clips perhaps.
if the car is not fitted standard with the seat belt warning ilum bulb, ipresume its not if blanked off already,
bl4ckclio
Post by bl4ckclio »
lozz wrote:Hello,.
yes, seat belt warning light as not standard equipment on my car.
but, do you any idea how to? or someone has done likes this........would appriciated.
maybe wiring diagram could help me a little :cheesy:
bl4ckclio wrote:
lozz wrote:Hello,.
Hi, not sure anyone as done this on the 406,
Mr earwig is the best person to ask for Wiring diagrams,
Regards lozz,
bl4ckclio
Post by bl4ckclio »
lozz wrote:
bl4ckclio wrote:
lozz wrote:Hello,.
Regards lozz,
thank you, Lozz
waiting for Mr. Earwig to comment :cheesy:
Bailes1992
Post by Bailes1992 »
My D8 1.9TD L used to have a seatbelt warning reminder.
Yet my D9 Rapier didn't? :?
Although I highly suspect my D8 was an ex emergency services vehicle.
lozz wrote:Mr earwig is the best person to ask for Wiring diagrams,
The car is a D8 and there are no wiring diagrams on SEDRE going back that far, sorry. I've been looking about for an older version but nothing doing I'm afraid.
I'm actually struggling to see why anyone would want to make this light work, it's not like you can't see the seat belts...
lozz wrote:you might need differnt seat belt clips perhaps.
That be right, they came with or without the alarm. Even if you got hold of the right ones there'd then be the question of wiring.
bl4ckclio
Post by bl4ckclio »
Bailes1992 wrote:My D8 1.9TD L used to have a seatbelt warning reminder.
yes
my car is D9 without seatbelt warning light.
specs in my country, Indonesia.
this is my car
bl4ckclio
Post by bl4ckclio »
as it's function....remind the driver to use seat belt :D
Oh, it is a D9, I searched your old posts and your car was a D8 :? I'll have a look later (off to town just now) but any chance of a build code? 2001 puts it right between semi- and full-mux.
bl4ckclio
Post by bl4ckclio »
steve_earwig wrote:Oh, it is a D9, I searched your old posts and your car was a D8 :? I'll have a look later (off to town just now) but any chance of a build code? 2001 puts it right between semi- and full-mux.
yes, I still have that "stupid" D8 :cry:
with the problem which haven't solved until now !!!!
don't know what have to do again.......
this D9 I bought a month ago, good condition I think :cheesy:
just wanna fully featuring which another 406 had.
what can I see to determine if my car semi/full-mux?
which I know, D9 use BSI.....not like D8.
bl4ckclio
Post by bl4ckclio »
just found this:
http://www.petrila.net/pug/Service/index.htm
go to 60 (Protection....assistance group) -> air bags/seat belt pretensioner
but I don't understand about how to read that code/symbol/wire number
maybe Mr. Earwig can help!
cheers
bl4ckclio wrote:what can I see to determine if my car semi/full-mux?
I suppose the easiest way would be to compare your column stalks to the D8's - semi-mux cars will be similar, full-mux cars have the good ol' COM2000 which has much bigger stalks.
Petrila only does full-mux 406s.
Nah, that one will do you, the one for semi-mux is the same except that it heads straight for the bulb in the instrument panel instead of the BSI. It appears to be a very simple system, if the driver's seat belt isn't plugged in it lights up a little light on the instrument panel, woop-de-doo. On a full-mux car you may (or may not) even get a bong! If the wiring isn't there (it's a 2-way white connector on the front of the seat) then I really, really, wouldn't worry about it.
