how activated seat belt warning light?
as topic
peugeot 406 2.0 16v
look at speedo clocks, there is seat belt warning light but blank off bulb.
I try to fill the bulb, but the light won't illuminated when the belt released from pretensioner.
anyone knows how to make the light illuminate when the seat belt released?
thanks.
Jay.
peugeot 406 2.0 16v
thanks.
Jay.
Re: how activated seat belt warning light?
Hello,.
you might need differnt seat belt clips perhaps.
if the car is not fitted standard with the seat belt warning ilum bulb, ipresume its not if blanked off already,
yes, seat belt warning light as not standard equipment on my car.lozz wrote:Hello,.
but, do you any idea how to? or someone has done likes this........would appriciated.
maybe wiring diagram could help me a little
Hi, not sure anyone as done this on the 406,bl4ckclio wrote:yes, seat belt warning light as not standard equipment on my car.lozz wrote:Hello,.
Mr earwig is the best person to ask for Wiring diagrams,
Regards lozz,
thank you, Lozzlozz wrote:Hi, not sure anyone as done this on the 406,bl4ckclio wrote:yes, seat belt warning light as not standard equipment on my car.lozz wrote:Hello,.
Regards lozz,
waiting for Mr. Earwig to comment
- Bailes1992
My D8 1.9TD L used to have a seatbelt warning reminder.
Yet my D9 Rapier didn't?
Although I highly suspect my D8 was an ex emergency services vehicle.
The car is a D8 and there are no wiring diagrams on SEDRE going back that far, sorry. I've been looking about for an older version but nothing doing I'm afraid.lozz wrote:Mr earwig is the best person to ask for Wiring diagrams,
I'm actually struggling to see why anyone would want to make this light work, it's not like you can't see the seat belts...
That be right, they came with or without the alarm. Even if you got hold of the right ones there'd then be the question of wiring.lozz wrote:you might need differnt seat belt clips perhaps.
yesBailes1992 wrote:My D8 1.9TD L used to have a seatbelt warning reminder.
Yet my D9 Rapier didn't?![]()
my car is D9 without seatbelt warning light.
specs in my country, Indonesia.
this is my car
as it's function....remind the driver to use seat beltsteve_earwig wrote:The car is a D8 and there are no wiring diagrams on SEDRE going back that far, sorry. I've been looking about for an older version but nothing doing I'm afraid.lozz wrote:Mr earwig is the best person to ask for Wiring diagrams,
Oh, it is a D9, I searched your old posts and your car was a D8
I'll have a look later (off to town just now) but any chance of a build code? 2001 puts it right between semi- and full-mux.
yes, I still have that "stupid" D8steve_earwig wrote:Oh, it is a D9, I searched your old posts and your car was a D8I'll have a look later (off to town just now) but any chance of a build code? 2001 puts it right between semi- and full-mux.
with the problem which haven't solved until now !!!!
don't know what have to do again.......
this D9 I bought a month ago, good condition I think
just wanna fully featuring which another 406 had.
what can I see to determine if my car semi/full-mux?
which I know, D9 use BSI.....not like D8.
just found this:
http://www.petrila.net/pug/Service/index.htm
go to 60 (Protection....assistance group) -> air bags/seat belt pretensioner
but I don't understand about how to read that code/symbol/wire number
maybe Mr. Earwig can help!
cheers
cheers
I suppose the easiest way would be to compare your column stalks to the D8's - semi-mux cars will be similar, full-mux cars have the good ol' COM2000 which has much bigger stalks.bl4ckclio wrote:what can I see to determine if my car semi/full-mux?
Petrila only does full-mux 406s.
Nah, that one will do you, the one for semi-mux is the same except that it heads straight for the bulb in the instrument panel instead of the BSI. It appears to be a very simple system, if the driver's seat belt isn't plugged in it lights up a little light on the instrument panel, woop-de-doo. On a full-mux car you may (or may not) even get a bong! If the wiring isn't there (it's a 2-way white connector on the front of the seat) then I really, really, wouldn't worry about it.
