Heating elecs
60dart
Heating elecs
Post by 60dart »
As promised in my intro, here is my question...... Is there a fuse connecting the display unit of the outside temp and the blower? My outside temp display has always worked and when the blowers stopped the other day, so did it. I have checked the fuses to the right of the steeringwheel, no joy, they appear to be n tact, im hoping this is an easy fix as nothing in denmark is cheap ( apart from me, but im an import) any help would be appreciated, thanks matt
Re: Heating elecs
Hello..Have you checked the fuse's under the bonnet ?
jonsowman
Re: Heating elecs
Post by jonsowman »
60dart wrote:nothing in denmark is cheap ( apart from me, but im an import)
Made me laugh :cheesy:
Blower died in my old D8, they do fail and need replacing unfortunately. Mine wasn't fitted with an exterior temp sensor though, so I doubt it's related. Can you check if there's voltage at the blower motor terminals?
Re: Heating elecs
HI & welcome aboard, Matt 8)
Popped out for a Danish, by any chance?
Went for a weekend in Copenhagen many moons ago - it was reasuringly expensive, but I do recall seeing quite a few drunken Swedes staggering aboard a ferry back home, (even dearer in Sweden, apparently)!
MY bro's D8 failed in a similar way, bur his was only a burnt up power connector on the base of the blower, which we bypassed.
60dart
Re: Heating elecs
Post by 60dart »
im going to bypass the lot tomorrow and check if the blower itself works, might rig up a temp thing so i can use the car. i think its strange that the outside temp display went at the same time.... cant see in the owners manual where the fuse for this display is either,. i will yank the big ones out under the bonnet 1 by 1 tomorrow also, its now about -4 and black outside, dont want to leave the fire.
copenhagen is extortionately expensive. i think the last time i went for a beer it was £7, after i got up, i went home.
Re: Heating elecs
60dart
Re: Heating elecs
Post by 60dart »
lozz wrote:
thanks for that, unfortunately it wasnt that, 20fuse is doing well. i have heard there is a 40 fuse near the steering wheel but i must be blind as i cant find it.
Re: Heating elecs
not listed as 40 fuse ! :?
60dart
Re: Heating elecs
Post by 60dart »
thanks again ......well, i give up. im not great at electrics and i need to use the blower, off to the mechanics it goes.
60dart
Re: Heating elecs
Post by 60dart »
has anyone got the wiring diagram for a 99 diesel...? mainly the heater system but im having no luck finding it, thanks
found out i have no power to the motor.... i ahte electrics :frown:
markw
Re: Heating elecs
Post by markw »
Re the outside temp sender...there isn't a separate fuse for this. It's just a two wire circuit from sender to BSI, (blue connector, terms 20 & 24.)
60dart
Re: Heating elecs
Post by 60dart »
ok so i guess it has nothing to do with the heater wiring then..? as they both stopped at the same time. i have a friend coming to help i hope wednesday, cheers,
Re: Heating elecs
60dart wrote:has anyone got the wiring diagram for a 99 diesel...? mainly the heater system but im having no luck finding it, thanks
99? hdi /xud??
don't know what car you've got but heres one for d9.
markw
Re: Heating elecs
Post by markw »
60dart wrote:ok so i guess it has nothing to do with the heater wiring then..? as they both stopped at the same time.
Could still be related to your fault, just saying there isn't a separate fuse that's all! :wink:
60dart
Re: Heating elecs
Post by 60dart »
i have an early 99 1.9 non turbo deisel :D (thats cold)
