So my window on the front passenger side was playing up. Then the other day giving a mate a lift home and he opened it, only for it to not go back up. The strange thing is it will still go down
So far i have done
1. New drivers switch, only £10 and my was playing up anyway
2. Another window regulator, same thing will go down not up
3. BSI reset, also left the battery off for an hour but no avail
4. I have noticed now as well that the drivers side will not operate the window down, only the passenger side
I have managed to use some wood to wedge the window up. But obviously this is not ideal
So I am assuming that it must be a broken connection somewhere. But where to I start. Could it be a wire running from the switch in the passenger side to the the motor?
Window issue driving me insane
Re: Window issue driving me insane
Thanks, will take a look tomorrow and the wiring if its dry. Wrong time of year really to have issues like this
I see you changed the driver's door switch, not the passenger's? They get wet too...
I've had the opposite problem, (won't open), several times on my nsr door and once on the front passenger door. Both sprang back into life after firmly operating the switches on the affected doors. Lack of use, maybe?
Tried another switch on passenger door
Tried a firm press but to no avail
Managed to use some wire to reverse the connector so managed to get it to go up, will disconnect the motor so nobody can put it down. Once the weather is better I will have a proper look
