I have this airbag light flashing, but when I use my OBD2 (WiFi) and OBD Doctor on my iPad I get no trouble codes besides P0380.
Is it possible there is a connection between the airbag light and the trouble code? If not, what can I do about the P0380 trouble code and the airbag light?
Agreed, it might not be capable of interrogating the airbag ecu. Or the airbag ecu might be dead... Did you try the usual suspects under the seat?
Incidentally, the glow plug circuit fault I've been told actually refers to detected faults on the glowplugs themselves. It still doesn't mean anything though as they all do that sir.
I will try to find a person with Peugeot Planet. Will the program work with most OBDII plugs that can be connected via USB?
I have bought the car for a couple of months ago, and the previous owner had fixed it and it worked for a while but then it came again. Nice to know, the P0380 is "normal". The engine runs perfect so I will just continue.
You need the psa interface lead afaik. Search lexia clone on ebay. pp2000 also requires windows xp. What area are you in? there may be someone local that can help out.
