Airbag light flashes but no trouble code
JensJakob
Post by JensJakob »
Hello.
I have this airbag light flashing, but when I use my OBD2 (WiFi) and OBD Doctor on my iPad I get no trouble codes besides P0380.
Is it possible there is a connection between the airbag light and the trouble code? If not, what can I do about the P0380 trouble code and the airbag light?
1987 Peugeot 205 1.9 GTi 8v
1999 Peugeot 406 2.0 HDI ST estate
rwb
Re: Airbag light flashes but no trouble code
Post by rwb »
Hi & welcome.
You're luck to get anything at all out of a generic scanner. This looks like a case for Peugeot Planet...
Agreed, it might not be capable of interrogating the airbag ecu. Or the airbag ecu might be dead... Did you try the usual suspects under the seat?
Incidentally, the glow plug circuit fault I've been told actually refers to detected faults on the glowplugs themselves. It still doesn't mean anything though as they all do that sir.
JensJakob
Post by JensJakob »
Quick answers - I like :)
I will try to find a person with Peugeot Planet. Will the program work with most OBDII plugs that can be connected via USB?
I have bought the car for a couple of months ago, and the previous owner had fixed it and it worked for a while but then it came again. Nice to know, the P0380 is "normal". The engine runs perfect so I will just continue.
OllieNZ
Post by OllieNZ »
You need the psa interface lead afaik. Search lexia clone on ebay. pp2000 also requires windows xp. What area are you in? there may be someone local that can help out.
JensJakob
Post by JensJakob »
Sorry for the late answer. I have ordered and recieved this: http://www.ebay.co.uk/itm/181415493539? ... 26_rdc%3D1
I will get my old XP laptop today and try to make the software work. I have tried on a emulator on my Windows 8.1 but it does not seem to work.
I am from Denmark so I am sadly a bit far from most of you :wink:
I think you might find someone nearer to you on the coupe forum http://www.406coupeclub.org/phpbb3/index.php
There are two forum members offering diagnostic assistance in Denmark
