Does your C beep?
Benner
Does your C beep?
Post by Benner »
As I have recently managed to buy another key and get it programmed (good old ebay!) I thought that it was about time to stop entering my code on they keypad when starting up my car, and to change to it all working from the key.
Anyway after looking up the proceedure (using C1C etc) I have noticed that when I press C I dont get any beep or anything.
Can somone just check for me that it does beep when its pressed before I try and repair it? I'm sure they are all the same but just in case, mines a '96 406.
Cheers all.
:arrowu: Damn fiddling D8's :roll:
If I can find my code, I'll check... but I bet there's going to be people here that actually took the time to memorise theirs... :)
Benner
Post by Benner »
Have noticed that my S doesn't beep either?
So it's either not meant to or I've got a cracked board.
andybee
Post by andybee »
just presss in ur code start the car up and uplug the key pad u wont need to put the keypad bk in untill the batter goes flat . then u need to put code in and same again. dont no if it work never try it
Benner
Post by Benner »
Yeah I've heard that and apparently it does work.
I would still like to have an immobiliser though, so can someone just check to see if they beep.
If they don't, it could just be me being a goon.
Pyros6546
Post by Pyros6546 »
all my keypad beeps, that is when i have to use it
which is very rare, or when i decide to change the code
Benner
Post by Benner »
Pyros6546 wrote:all my keypad beeps, that is when i have to use it
That's what I thought :|
So I must have a cracked board, unless someone knows if a split wire in the loom could cause this problem?
I just want to use it with the key but I cant enter the C1C to stop it. :x
Thanks for the response Pyros!
