descanso
Posts: 19 Joined: Fri Jun 01, 2007 1:04 am
Post
by descanso » Sun Jun 24, 2007 11:50 am
hi,
I will need to take battery off the car soon, but I'm worried because I don't have the radio code si eventually after relacing the battery I won't be able to listen to the radio
Is there anything I could do to obtain the code?
How much does peugeot charge for resetting that for you?
thx
TooT
Posts: 1228 Joined: Sat Mar 24, 2007 1:34 pm
Post
by TooT » Sun Jun 24, 2007 11:56 am
I dunno what radio model you have but i when i had to buy a new battery for mine i did not need to put a code in when i reconnected it.
Posts: 5377 Joined: Sat Aug 06, 2005 8:24 am
Post
by DaiRees » Sun Jun 24, 2007 12:57 pm
If it's a D8 I think they charge about £25 to get the code.
If it's a D9 you don't need a code.
Playtime_Fontayne wrote: "Dai Rees Supplier of Fine Automobilia. Established 2007"
jameslxdt
Posts: 2512 Joined: Wed Apr 26, 2006 9:30 pm
Post
by jameslxdt » Sun Jun 24, 2007 5:08 pm
yup as Dai said, the D9 radios are coded by VIN no, so there is no code to put in, take the radio out, sometimes ive found people to write the code on the radio, if not you will have to go to the dealer to get the code
descanso
Post
by descanso » Sun Jun 24, 2007 5:41 pm
It's a mark 1
Well, £25 aint too much... I hope it aint much more than that.
grrrr
wes1001
Posts: 177 Joined: Tue Dec 19, 2006 9:10 am
Location: Sticky out bit, right on the tip of Kent, practically in the channel !!
Post
by wes1001 » Sun Jun 24, 2007 6:13 pm
Also check in the handbook ( if it came with one ) as some nice chappie had scribbled the code down for mine on the inside of the cover - could be worth a look
PJ
Posts: 182 Joined: Wed Aug 03, 2005 11:34 pm
Post
by PJ » Sun Jun 24, 2007 7:34 pm
If you're not lucky enough to have the code on the radio.
Take the radio out, get the details then try here :-
http://radiocode.proboards6.com/index.cgi?board=general
It's been quite successful in the past.
axl
Posts: 16 Joined: Sat Aug 27, 2005 11:34 pm
Post
by axl » Sun Jun 24, 2007 7:54 pm
if the radio has been in the car from factory i could find it by VIN of the car.
axl
descanso
Post
by descanso » Mon Jun 25, 2007 1:21 am
axl wrote: if the radio has been in the car from factory i could find it by VIN of the car.
axl
should I PM you the VIN, if you would attempt to do it?
I am quite positive it's original radio.
philg
Posts: 93 Joined: Sat Apr 21, 2007 6:49 pm
Post
by philg » Mon Jun 25, 2007 4:19 pm
exactly what i did with my radio, got the code for free.
axl
Post
by axl » Mon Jun 25, 2007 6:35 pm
descanso wrote: axl wrote: if the radio has been in the car from factory i could find it by VIN of the car.
axl
PM
