radio code
descanso
1.6 8v
radio code
Post by descanso »
hi,
I will need to take battery off the car soon, but I'm worried because I don't have the radio code si eventually after relacing the battery I won't be able to listen to the radio :(
Is there anything I could do to obtain the code?
How much does peugeot charge for resetting that for you?
thx
TooT
Post by TooT »
I dunno what radio model you have but i when i had to buy a new battery for mine i did not need to put a code in when i reconnected it.
If it's a D8 I think they charge about £25 to get the code.
If it's a D9 you don't need a code.
jameslxdt
Post by jameslxdt »
yup as Dai said, the D9 radios are coded by VIN no, so there is no code to put in, take the radio out, sometimes ive found people to write the code on the radio, if not you will have to go to the dealer to get the code
descanso
1.6 8v
Post by descanso »
It's a mark 1 :(
Well, £25 aint too much... I hope it aint much more than that.
grrrr
wes1001
Location: Sticky out bit, right on the tip of Kent, practically in the channel !!
Post by wes1001 »
Also check in the handbook ( if it came with one ) as some nice chappie had scribbled the code down for mine on the inside of the cover - could be worth a look :cheesy:
PJ
Post by PJ »
If you're not lucky enough to have the code on the radio.
Take the radio out, get the details then try here :- http://radiocode.proboards6.com/index.cgi?board=general
It's been quite successful in the past.
axl
1.6 8v
Post by axl »
if the radio has been in the car from factory i could find it by VIN of the car.
axl
descanso
1.6 8v
Post by descanso »
axl wrote:if the radio has been in the car from factory i could find it by VIN of the car.
axl
should I PM you the VIN, if you would attempt to do it?
I am quite positive it's original radio.
philg
Post by philg »
PJ wrote:If you're not lucky enough to have the code on the radio.
exactly what i did with my radio, got the code for free.
axl
1.6 8v
Post by axl »
axl
PM :)
