Washers have died... Arggghhh!!!
Re: Washers have died... Arggghhh!!!
haven't got headlight washers so cant help , sorry :cry: :cry: :cry:
My god the D9 Haynes (I may have 'acquired' a pdf) has the worst wiring diagrams ever. It doesn't even have a list of the engine bay fuses!
According to it, It's fuse 25 and the washer motor's wired directly to the stalk? Then again, according to the D9 Haynes, the rear washer pump will never work because the + and - are both connected to the same line! And it's the number of the front pump not the rear. My god I'm glad the D8 Haynes isn't anywhere near this bad!
Easy check soops is to shove a bulb or multimeter over the terminals on the pump connector (find it in the front of the right wing, access via the o/s/f wheelarch liner). If there's power there, it's just a new pump you need
mbell666
Post by mbell666 »
It'll be a fuse in the engine bay fuse box, mine used to blow almost everytime if i used the headlight washer in icy conditions.
From memory its a 10 Amp, but not sure what number, its a case of pull them out till you find them. It might actually say on the rear of the lid what each fuse does, you never know with a pug!
1997 Honda Prelude 2.2 VTi
Haynes fuse listing confirms Fuse 25 in passenger compartment fusebox, for front & rear wash/wipe, (20 Amp).
Agree with mjb, Haynes diagram = pure b0ll0cks, rear washer pump is misidentified & I suspect wash/wipe switch terminals are mislabled on 'Rear wash/wipe' diagram.
Do the headlamp washer jets have a separate pump? What lifts them, water pressure?
you sure they not frozen soops... mine were and not making any
sound at all then just suddenly spurted...
LMFAO !!! i was actually :oops:
Yes i do ... how long would they keep todays kids occupied :shock:
Exactly ! if its not a comp or plugs in back of tv forget it :cheesy: :cheesy:
supafrisk wrote:ust wondering what sound they would make... do you remember those "cow in a can"s you used to get as a kid? The ones you used to shake from one side to the other to moo? :shock:
Beastie Boys - Paul's Boutique - Sounds of Science
They're making them in Delicatessen, which is a strange yet brilliant French comedy about cannibalism.
There's also one on a shelf half way up my mate's mum's stairs as an ornament - *spots something on the way to the bog* "hold on, that looks like one of those..." "MOOOOO!" "oh my god!"
I reckon they're frozen?
Syphon out the screen wash and poor in a load of warm water, let it rest for 30 mins then try again?
Finking about it - cos you must get through so much screenwash then sometimes the cheaper stuff can congeal at the bottom and block up the inlets to the pumps.
I had to syphon (and flush at the same time) my mums screenwash bottle as the previous owner had used 'god knows what' in there and it was minging :shock:
Cool!, I mean 'cool'....I mean err.....
Funny, I've been squirting quite a lot last few days with no trouble 8)
:arrowu: :arrowu: Pervert !! :roll:
Welton wrote:Funny, I've been squirting quite a lot last few days with no trouble 8)
I just seem to be spraying white gunk over the screen at the moment... :shock:
:arrowu: :arrowu: A bigger pervert !! :twisted: :P :P
You need the later type 'mist' washer jets - either you won't be able to tell the colour of the gunk, or it'll never reach the screen :supafrisk:
