central locking
central locking
the central locking has failed on just the rear o/s door on my 1999 406, all the rest of the locks work fine both with the key & fob, could anyone help shed some light on this problem. regards Keith
Re: central locking
Hi there
First you need to remove the door card, you will then see the central locking mechansim mounted at the top of the door where the door handle is located. It can be identified by looking on the outer edge of the door, you will be able to see the torx head bolts holding it in place. There is some plugs that go into the unit, remove them and ensure the contacts are clean, spray some WD40 into them and plug back in. Check if the mechanism is working again and if not you will need to replace the mechanism.
Hope this helps
Hope this helps
Re: central locking
(at last) got round to sorting that door lock, thanks very much for your help
Re: central locking
Come on then, what was it?
Re: central locking
sorry! it was just damp & a bit of corrosion on the connections. squirt of wd40 & all was good again ( till the next thing goes wrong)
- Site Admin & Mad Biker!
Re: central locking
Come on Keith, positive mental attitude!keithmorris68 wrote:( till the next thing goes wrong)
Re: central locking
Positive mental attitude? Try having one of those with an empty bank account
Good job anyway
Good job anyway
Re: central locking
With the choice of laughing or crying I choose to laugh, beats depression any day when robbing Peter to pay Paul.steve_earwig wrote:Positive mental attitude? Try having one of those with an empty bank account
