Hi,
Sorry if this has been talked about loads of times before.....
Basically, the Phillips 6CD Changer in the boot has seen better days. Question 1 - does any body know if I can find a connector to connect an after market CD changer to the 12pin? Din (looks like an old fashioned 5 pin audio din connector, but it's got way more pins) lead in the car.
If not, any thoughts on connecting a replacement aftermarket radio/cd/mp3 etc with built in hands free bluetooth for the phone? I would really like to find a use for the existing audio display, and my research tells me that the chances of find an after market unit that will use this for anything are slim. I will want to reconnect the stalk and I see there are loads of companies offering these - is any one better than the other?
Lastly, anybody know what I am going to find in terms of connectors etc if I pull the existing 4050 unit out - my car is pretty much as it left the factory in 1998.
Replace 406 GLX Mk1/D8 ICE
- ECA
Re: Replace 406 GLX Mk1/D8 ICE
Hi mate
I know this is an old thread but just in case your still trying to sort it out.
I think you'll be struggling to get an aftermarket changer to fit - you can get them for the later D9's but not yours I dont think
Stalk control leads are easy to get but again with the earlier cars I think you will lose the display.
As for head unit
http://caraudiosecurity.com/shop/produc ... 11730.html
this should do the job and it will work from the stalk (with the right adaptor)
Hope this helps a bit
As for head unit
Eclipse Car Audio
http://www.eclipsecaraudio.co.uk
52 Reg 406 Rapier HDI estate
09 reg Vauxhall Astra Design 1.7 CDTI EFX
S Reg Ford Fiesta Van
- Leopold
What a Bargain, and its Bluetooth..ECA wrote:
As for head unit
'99 Peugeot 406 1.8 16v LS in Jade Green
- 1.6 8v
A belated thanks for the replies. Not solved the problem as yet but thinking about buying another unit off flea bay or a scrappy; I had hoped the existing unit would hold a pin out inside the case so I could make an adapter cable, but not such luck
