Auxillary input?
Auxillary input?
Is there a way of wiring an auxillary input to the Clarion headunit in my D9 406? It's the kind with a sat nav cd in the boot. All I want to do is plug an MP3 player or phone into the thing. Controlling it from the head unit like a CD changer isn't important.
406 110 Estate
Re: Auxillary input?
I think you can "cut" into the cd changer wire and use that, but you need to do something so that you can switch between cd changer and MP3/sat nav.
pretty certain someone on here did it but was long time along so thread may have gone when we got hacked.
1997 Honda Prelude 2.2 VTi
I asked a similar question to a shop on eBay which makes and sells adaptor cables which allow the CD-changer socket on the head unit to become an Aux input instead. He said no way can it be done on my headunit, which is a shame. SOMEBODY must know how it can be done.
Tony
Tony
2003 406 90HDI Saloon in Silver.
- ianst28
- 2.2 16v
- Location: sunny wirral (who am i kidding it's always bl&^%y raining)
ok there is a company called connects 2 who make an adaptor for the 406 clarion vdo unit
the part number is CTVPGX010
but and it's a big but this is designed to go in place of the changer it plugs in and gives you a 3.5mm jack plug to use but you loose the changer
hope this helps
hope this helps
If at first you don't succeed, skydiving is not for you !!!!!
Hi all, I have finally tried the Connects 2 adaptor thingy.
I decided to ask No.1 wife for one instead of getting the usual CD's and other stuff I dont need for Christmas.
Cheapest one I found is here;
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0304684996
It is a small plastic box, and comes with cables, one goes to the blue socket on the radio and the other is a twin Phono to 3.5mm stereo jack plug.
The box contains a circuit board with components and sockets. It is worth the price, it is not just a junction box.
Fitting took about 20 mins. I had to remove the green and yellow plugs as well, but did'nt lose the radio code.
I intend to add a 3.5mm jack socket somewhere on the radio facia, but I have just left the input cable hanging out of the facia for now.
When I pushed the 6 cd changer button, the display shows one CD in changer, with 2 tracks.
My car has the CD changer cable to be boot, but no changer fitted.
I used the adaptor with a Pure Pocketdab 1500 dab radio.
I was worried that because this radio uses the headphone cable as the aerial, that the adaptor might ground the dab signal, but it worked very well.
Tony
Tony
Belated thanks to Ian for the info about the Connects2 thingy.
Cheers
Tony
Also on the Wirral.
Cheers
Tony
Also on the Wirral.
