306 tdi ticking when key turned on before starting ?
Phil406
Post by Phil406 »
hi guys,a friend of mine has a 306 she had to pull over as smoke coming from steering colum and ticking coming from somewhere.a 20a fuse was replaced be when you turn key it sounds like flashers are on untill you start engine,she also has no lights in centre ie: fan dials etc,all fuses seem to be ok, any ideas on what could be causing this ?
thanks phil
2.0 HDI 110 jan 2002.
StevieboyTD
Re: 306 tdi ticking when key turned on before starting ?
Post by StevieboyTD »
Indicator stalk has died, pick up another one form the scrapyard.
Regular failure on the 306.
2.1td exec estate.
Phil406
Post by Phil406 »
steve they work ok and stalk seems to work fine,could it still be that ?
StevieboyTD
Had if fail on our last 2 306s. Quick test is to unplug the indicator stalk and see if the ticking stops, the smoke would have been the grease & soft plastics inside the switch melting.
2.1td exec estate.
Phil406
Post by Phil406 »
ok thanks steve i'll have a look at it for her :)
Bailes1992
Post by Bailes1992 »
Mine went on my D8, caught fire on the M50 too :lol:
