Now I have 2 pugs on the drive which were built this century I'm seriously considering picking up PP2000.
After a quick Google there appears to be some at around £40 and some in the £70+ area, I'm at work so can't dig around properly.
Are they the same thing or do I need to go for a specific one for a 53 plate 406 and a 54 plate 307?
Thanks in advance as per usual and expect another post soon entitled 'PP2000 how the f*%k do I use it'
PP2000/Lexia3
PP2000/Lexia3
Re: PP2000/Lexia3
pp200 goes to 2000 then you need lexia have a look at the other post on here
Re: PP2000/Lexia3
My PP2000 clone works on everything I've tried up to around 2007.
AFAIK the going rate is around £70 / £75. If you're tempted by something cheaper, post a link to it and one of us 'users' will vet it for you.
- rwb
Re: PP2000/Lexia3
Yep, £70 seems like the going rate.
You may be able to pick up the hardware for less... we can provide a disc...
I have PP2k working on my 2007 407. The 508 is absent from the menus. Even so, I think that's just a software thing and not a difference in the hardware.
For newer models you need diagbox rather than PP2k. I've failed to install it a couple of times, but Jasper5 has a working installation.
For the 406, anything contemporary with the car is all you need, so PP2k is fine.
- Captain Jack
Re: PP2000/Lexia3
Diagbox is awful - Fisher Price interface is S-L-O-W on my Core2Duo laptop. I have it working but I can't seem to get it working alongside Lexia/PP2000 - so it's one or the other. I've chosen Lexia3/PP2000...
I've heard cheaper ones sometimes don't come with all the cabling but I've only ever needed the OBDII one so far...
Re: PP2000/Lexia3
What & where did you buy yours?Doggy wrote:My PP2000 clone works on everything I've tried up to around 2007.
Re: PP2000/Lexia3
Got mine about 4 years back when they were a lot dearer - cost me £155.
Re: PP2000/Lexia3
Never mind me I was talking twaddle.
Searching at work I couldn't get into most of the sites and just got the item price, the cheaper ones didn't include P&P which basically brought it up to the £70 mark.
Re: PP2000/Lexia3
i got mine from this guy in the uk about £60 and i heard from another forum he is good at helping if you have a problem which i didn't worked first time
http://www.ukpolboy.comoj.com/1_8_Lexia ... cable.html
