mondeo tdci 130 hesitation
Just got car back from garage after suffering from hesitation was told that both rear calipers were completely seized so had all calipers changed along with discs and pads
picked car up but its still hesitaing but not as bad as b4
just wondering if there could be anything else maybe injector need cleaning
car is mondeo tdci 130
Re: hesitation
injectors spring to mined knowing the rep they have for them as thay are calibrated and this is then put into the ecu, so as they where they fall out of calibration and this then leads to black smoke, hesitation and other problem but i am jumping to conclusions
what year and all the rest is it
Re: hesitation
53 plate there is alot of black smoke under acceleration
would this affect fuel consumption cos after all brake work struggling to mid 40 mpg
Re: hesitation
yep all the signs that you may need an injector rebuild or replacement, just make shore you are sitting down when you phone for a quote. do all the checks you can just to save some moneys before you decide what do to with it i.e. checking for split pipes and blocked filters
- Bailes1992
Re: hesitation
As it's a Mondeo I suggest signing up to the talk ford forums! Have a good look ink EGR blanking as it will more than likely cure your hesitation.
Re: mondeo tdci 130 hesitation
Just purchased egr blanking plate so hopefully hesitation will stop and mpg will come back up
how easy are the plates to fit do you need any sealant
i`m not counting my chickens just yet but a £3 blanking plates seems to have done the trick no black smoke under acceleration and no hesitating fuel consumption back t0 43 running round town not sure about motorway yet no tried it
I had all sorts of things going round my injectors tps cam sensor
thanks again everyone who helps me even though I no longer run a 406
- Bailes1992
Me and Dai disabled the EGR on a friend on his MK3 a few months back!
Although we didn't buy a blanking plate. We did the manly thing and made our own out of a sheet of steel!
There was sparks, loud noises, drawn blood etc etc
That sounds like the sort of stupid thing I'd do, spend ages making something up when I could've bought one for almost nothingBailes1992 wrote:There was sparks, loud noises, drawn blood etc etc
- Bailes1992
steve_earwig wrote:That sounds like the sort of stupid thing I'd do, spend ages making something up when I could've bought one for almost nothingBailes1992 wrote:There was sparks, loud noises, drawn blood etc etc
It was the case of we had to do what we could with what we had!
We had fun anyway
Now that I can understandBailes1992 wrote:fun
There is still a slight hesitation but fuel economy is crap there doesn't appear to be much boost from turbo
could the pipe that comes from the bottom of egr to the intercooler be split cos not got the funds to take to a garage as i am enforced sick from work
any help would be appreciated
thanks
thanks
- Captain Jack
Yep, a split pipe or boost leak is a good possibility.
Wll that cause the poor fuel consumpton ps i have removed the blanking from the egr
Very common for the TDCi to have split intercooler pipes, the one at the driver's side being the main culprit.
