How hard to change anti roll bar drop links?
jason1987
Post by jason1987 »
will it cover it in a haynes manual? as i think mine need changing as i get a knocking noise over bumps and steering feels a bit wooly
jason1987
Re: How hard to change anti roll bar drop links?
Post by jason1987 »
well on the last mot it said slight play in arb drop link so i assume its that? or is it more likely to just be a bush? what do i need to look for?
For the front: Crack the wheel nuts, jack up, support with axle stands, take the wheels off, liberally soak the ends of the drop links in WD40, go to sleep. Remove the drop links the next day (should be a hole for an allen key to keep the ball joint still, then an open-ended spanner round the outside, but these can rust badly and might need angle grinding off!). Then put your new ones on. Dead easy if you can get the old ones off through the rust
jason1987
Post by jason1987 »
how do i know if it def is the links? will it be obvious by looking if its the bushes? also will a haynes manual tell me how do do all these things, and to fit lowering sprins for example and things like that?
jason1987
Post by jason1987 »
ive got the wheel off but cant see any obvious signs of wear/damage, ill go take a pic now tho
jason1987
Post by jason1987 »
jason1987
Post by jason1987 »
rang camberley auto factors and they have one in stock, £17.50 plus vat, is this about right?
Sounds ok, just make sure you get the right ones - yours are the early sort with the bottom pin straight down.
jason1987
Post by jason1987 »
my mot said nearside anti roll bar link has play so ill change the left one as they only have one in stock, and i looked at both sides and cant see any difference so ill go for the one it said on the mot
jason1987
Post by jason1987 »
so does the bottom bit of the drop link come off the same way as the top? allen key in and turn with spanner?
I'd guess so, have a squint from underneath.
jason1987
Post by jason1987 »
im having trouble with moving the nut, it just starts to spin if i use the ring end of the spanner
Perhaps you could use a socket wrench to get it moving, failing that could you hammer an 11/16th" on there?
jason1987
Post by jason1987 »
i havent got an 18" spanner nor an allen driver, so im gonna have to go and get those tomorrow. hopefully it the wd40 will have made it looser by tomorrow aswell
