Hi,
I have just bought a 406 Executive Hdi estate, year 2000 (W reg).
It only has 3 alloy's fitted, apparently a pot hole during the snow's did for the other wheel so the spare steel wheel was fitted and is still there.
So, has any one got an alloy wheel c/w tyre going cheap, preferebly somewhere near Northampton.
I am also looking for a tow bar as well.
Regards Ed Nikel.
406 Executive estate Hdi, 2000
Singer Chamois 1969
Dellow trials car 1956
Tow bar and Alloy wheel wanted
- 1.8 8v
Ed
2000 110 HDI Executive Estate
1991 Saab 900i auto
1969 Singer Chamois
1956 Dellow trials car
1991 Saab 900i auto
1969 Singer Chamois
- 1.6 8v
Re: Tow bar and Alloy wheel wanted
couldn't find a used towbar for my car and ended up paying £150 to have one fitted-good luck!
i have a spare 15 inch alloy from a d8[also what wheel bolts are you useing as alloy ones are diffrent from steel ones}
towbar
just be aware that you have to get one from a estate as the saloon ones are diffrent.
towbar
- 1.8 8v
Re: Tow bar and Alloy wheel wanted also parcel shelf
Hi,
Thanks for the info!
Omega- what are D8 wheels ? is this code? what does it mean?
My car is a 2000(W reg) Hdi 110 executive estate with 195 65 R15 tyres. Will this wheel fit? Do you have a photo? Where abouts are you?
The steel wheel fitted was the spare so presumably peugeot would not allow a steel wheel to be standard fit if the bolts didnt fit correctly!
There is a fixed washer/spacer attached to the wheel!
Also looking for the load space parcel shelf cover. Anyone got out there got one going spare?
Regards,
Ed
Singer Chamois 1969
Regards,
Ed
Singer Chamois 1969
Ed
1991 Saab 900i auto
1969 Singer Chamois
1991 Saab 900i auto
1969 Singer Chamois
hi
a d8 is the early model up to about 2000 and yours is a d9 facelift model if you do a search on here theres a large thread telling all the diffrences
i didnt know they had a washer on the wheel so should be fine
the wheel i have will fit but will be a diffrent style to what you have
im in nottingham
im in nottingham
- musso2010
- 1.8 8v
I have a tow bar with 2 electric points. Make me an offer, Cheers
406 TURBO
Lowered 80mm
13psi Boost
Bailey Dump Valve
Full Powerflow Stainless System
Induction Kit
good bye MR2's!
Lowered 80mm
13psi Boost
Bailey Dump Valve
Induction Kit
good bye MR2's!
- 1.8 8v
Thanks for the replies.
I now have a wheel and the load space cover. I found them at a local breakers!
Still looking for a towbar.
Have emailed you Musso2010.
Regards Ed Nikel.
Singer Chamois 1969
Regards Ed Nikel.
Singer Chamois 1969
Ed
1991 Saab 900i auto
1969 Singer Chamois
1991 Saab 900i auto
1969 Singer Chamois
