I know you`ve done it already but to answer the question ...........Bailes1992 wrote:How easy is it to remove the rest of the boot pull? Is the bit that you pull to open the boot seperate to the boot pull that I've broken? How is the actual handle held on?
remove tailgate interior panel
then there are 2 x torx bits to undo , need an extension for torx bit otherwise it takes ages to undo and then retighten the 2x screws/bolts that hold the handle .Thanks to StevieG at FCS who came to my assistance when I was replacing mine at FCS ( French Car Show ).awesomely comprehensive toolkit he carries.
