Loads of diagrams on Google:
(Ignore 87a)
That's essentially correct.406executiveHDI wrote:whats a coil suppression diode, is it a reverse bias diode to prevent back EMF caused by the magnets in the relay from sending a high voltage back into the bsi,
Don't know. I think the BSI uses relays as the switching device, (it definetely does for a/c clutch, hrw, etc. but clearly can't for interior lights as they fade in/out), so we can't be sure.and after asking an ebay seller about a relay i was told the input side resistance is 85ohm and using ohms law that means 0.16amps or 160miliamps is that ok for the bsi?
yes mate as the normal bulbs use alot more current for them to work so if using leds both ways then it should even out the currentsteve_earwig wrote:This is getting too complicated![]()
What about swapping the puddle light bulbs for LEDs and using LEDs in the footwell lights? Would this drop the current enough to keep the BSI happy? Or wouldn't they be bright enough?
