HDI 110 ECU location?
As title says, where can I find my ecu? I need to find out what ecu I have in my 2000 W plate hdi 110?
Re: HDI 110 ECU location?
The engine ecu is at the front off side of the engine bay. The oposite position to the battery. Its quite big with a big conector on top. When it left the factory it would have been in its own box which you will have to take the top off.
Hope this helps.
Richard
Hope this helps.
Richard
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
Thank you very much I shall take a peek later on
Before I removed the cover I thought it was something like a secondary air pump or some kind of breather system. Then when I was told it was the ecu box I took the engine cover off and could see the electrical wires inside the plastic hose protector stuff.
