any1 with a parts booklet ?
can you buy new rear light seals from stealers ? and what sort of price are they,
or is it best to just silicone my old ones, (got free silicone i use it at work)
REAR LIGHT SEALS
REAR LIGHT SEALS
Re: REAR LIGHT SEALS
id try the free solution first as you can always try the dealer option later.
It doesn't look like itGary406 wrote:can you buy new rear light seals from stealers ?
im glad u said that ste, cos ive done it this way now
ive used transparant sealant on the light itself all on the inside of the seal, and also on the body were the seal meets ,
also were the the clear bit meets the black bit on the lenz part,
that should defo seal it ive used plenty
car is bone dry inside, i was shocked to find under carpets wasnt wet, hopefuly now my amps wont get full of condensation
thanks for replys
thanks for replys
may have been a good idea to get sum lexus style lights, they come with new seals,
just wish they would make a nice set because the ones available now are real crap, hate that silver shiny effect,
the silicone should do ok, if you sealed yours up today, and i did mine about 3 weeks ago then theres plenty of advance notice if water will start coming back in, but i doubt it will again.
seems to be a result. pissed down all last night and no water insode the lights, more important my amps had NO condensation,
