I have screechy/squeling brakes they work fine and everything I just look abit of a knob pulling up to people sounding like my mum after too many pinot grigio's (trying 2 sing)
How can I fix this? is it new brakes or can I use copper grease or something? the pads and discs look fine and it only makes the noise at a certain point and when braking at a certain speed but its driving me mad!! plz help
And also 1 other thing which I know is common but is there a way of sorting out the whining noise coming from the car when cornering at very low speeds like round car parks?
I would put some copper slip on the front pads. Try not to jet wash them after, it tends to wash the copper slip off .
The rear (if disc's) should have anti sueal pads. if you've had new pads they might not have been re-fitted. I changed my pads a few weeks ago and couldn't fit the anti squeal pads back because there wasn't enough room for brake and anti squeal pads!
Mine only seam to squeal when i am going backwards. May get some new anti squeal pads when my brakes are a little more warn.
