I dont like rattles or squeaks, so the door has been squeking ever since i put new cill seals in it, and i checked all the clips and they were ok so i was confused, but i looked closely and the cill seal was causing the squeak because it was rubbing, so the solution to anyone with the same problem is to get a dab of vaseline in round the seal under it and on top, stops the squeakyness straight away. You could use grease but it smells bad and ruins clothes so vaseline was the better choice.
I also used it on all the door seals, it seems to have brought back their original stretchiness and will hopefully make them last longer.
Squeaky door, freshen up seals tip
