need a boot seal for a d8 saloon, mine it ripped and tore all round, having siliconed the lights and under the rear window water is still running in spare well,
it looks like its running in from the back end under that peice of solid plastic that sits right at the back on the inside,
boot seal wanted
boot seal wanted
Re: boot seal wanted
gary, you're best bet is a breakers yard, you can at least check the condition before you pay. I replaced mine when I changed a cracked rear light cluster to be on the safe side. If memory serves I only paid a few quid and got one in quite good condition.
2003 2.2 HDI SE
2003 2.2 HDI SE
Breakers are indeed the best choice, a d9 one should do you car also
ok thats mate didnt know d9 would do it,
