Door skin seal
Door skin seal
I was wondering does that foam thing that keeps the doors watertight is the ones on d8 different than d9s, i see one on ebay but it says phase 1 surely there is not much difference?
Re: Door skin seal
An unawnsered post here
- highlander
- PowerFlow Shill
Re: Door skin seal
I know what mine look like on the saloon, from having swapped out the door cards. If you show me a photo of the ones from the D8 you're looking at, I could tell you if they're different from the D9.
However, remember that saloons and estates have differently-shaped rear doors; I imagine the seal is also different as a result.
Re: Door skin seal
here it is, i know i was creative with the passenger side seal, but have just decided to do it right, and the back one needs done right.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 2655wt_907
- highlander
- PowerFlow Shill
Re: Door skin seal
Looks like it is the right part; they seem to be the same between D8 and D9 (that is, the D8 part number on your eBay auction is the same part as it was on Service Box when I used it to look up a D9 HDi 110 4-Door Saloon):
However, your front doors are a bit different because they're either reinforced (SIPS) or not reinforced; the part numbers are different for each one.
Not sure which you'll have.
Code: Select all
9365 P9 - REAR HINGED SIDE DOORS - SEALING SHEET - LEFT (ELECT CONTR RR WINDOW LIFTER)
9365 Q0 - REAR HINGED SIDE DOORS - SEALING SHEET - RIGHT (ELECT CONTR RR WINDOW LIFTER)
Code: Select all
9002 Q3 - FRONT HINGED SIDE DOORS - SEALING SHEET - LEFT (DOOR WITHOUT REINFORCEMENT)
9004 Q1 - FRONT HINGED SIDE DOORS - SEALING SHEET - RIGHT (DOOR WITHOUT REINFORCEMENT)
Code: Select all
9002 Q4 - FRONT HINGED SIDE DOORS - SEALING SHEET - LEFT (DOOR WITH REINFORCEMENT)
9004 Q2 - FRONT HINGED SIDE DOORS - SEALING SHEET - RIGHT (DOOR WITH REINFORCEMENT)
