Setting service interval display ...
As title , i've tried setting it as instructed in handbook but it is still
showing a "0" and a spanner , is there a different way to set it ??
Re: Setting service interval display ...
Never read the handbook :oops: , but mine works the same as my previous Cistern....
hold trip counter button down while turning key, continue to hold till it displays 12500
have tried that doggy , 12,000 appears but when i let go it starts to
countdown from 10 seconds , are you supposed to start the car then
or switch the ignition of first because it just goes back to spanner
and zero :shock:
hold it for longer - we'll check if you're OK in the spring. :lol:
As best I can remember, it should go to 12500, then I think it just stops flashing :?:
next spring my arse ya cheeky git :P will try holding it longer .
You can also make it count down from a lesser mileage (9000 I think?) by pressing it again after? I used to do this as my mileage was less than 9K a year.
DiscoPol
Shiny New C5 2.2 Bi-turbo!
Post by DiscoPol »
puggy wrote: will try holding it longer .
at your age Puggy its nothing to be ashamed of :P
sirwiggum
Post by sirwiggum »
I reset mine to 12500 after doing the oil and filters.
Just have a mental note to service it again after 6000 or so miles but to leave it.
Then when the original 12500 runs out service again and reset again.
12500 is wayyy too long! Oil ends up looking like sludge!
Fook me !! he's in poland and still taking the pisss :cheesy: :cheesy:
You concentrate on turning your tank into a submarine young man !! :twisted:
DiscoPol
Post by DiscoPol »
puggy wrote:You concentrate on turning your tank into a submarine young man !!
done that :( im working on something that will make it amphibious, getting in the water is dead easy, its the getting out i struggle with :oops:
Ok you were right i wasn't holding it for long enough :oops: but it does only go
to 12000 and not 12500 :shock:
Oh no! Will you be taking it to the dealers to have this looked at? :P
:P :P Well steve i was seriously considering that course of action as
i hate to be different and i think it is quite a mystery why it is my car
it is happening to .
probably needs shorter intervals cos of the power its putting out :twisted:
puggy wrote:probably needs shorter intervals cos of the power its putting out :twisted:
Ah!, that's your problem. You need to stop 'putting it out'. :roll:
Try to get what little there is, to the wheels. :twisted:
PAH !!! dont you just hate people with 180bhp on tap :(
[*]walks away to sulk and kick as many family pets on the way he can[/i]
