110 hdi low fuel pressure
- Newbie
low fuel pressure problem.2001 110 hdi. ive already changed the pump in the tank in november but now i have very low pressure at fuel rail.ecu checked out ok.any one else had this problem?wiring problem or high pressure fuel pump????
- Newbie
- Foghorn Leghorn
- 2.0 Turbo
Also a nice tank full of Unleaded does nothing to help the pump(s).
On some cars you might just get away with it if your quick, but the damage is done, the pump will still fail later on.
Tis a real shame the HP pump is so expensive, it won't be long before a pump failure will effectively write the car off
- Newbie
