195/65/15's
195/65/15's
after either a set of the above tyres, on rims, or not! local to essex really so postge not needed!! anyone breaking a 406??
406 '01 110 GTX estate in white, the new tow car.
- waue1978
- HDi don't believe it!
Re: 195/65/15's
I'm not local to Essex (Andover, Hampshire), but I do have a set of steels & trims that are in the way if you don't find any closer to home. All Vredesteins with fairly good tread.
Re: 195/65/15's
Hi, what sort of money are you after for them? I could make the trip this weekend if your about and for the right price! Cheers ian
- waue1978
Re: 195/65/15's
Not after a massive amount to be honest. Only thing I've got a price in mind for is about £20 for the trims as that's probably what I could get for them on Ebay (& they can be posted!). Have just been out to check the treads & they all have 3-4mm going across the top (3 at edge 4 in the middle). 1 seems to have lost a bit of air, but other 3 still seem to be fully inflated & they've been sat next to the shed for 3 months now.
Have a work out how much it'll cost you to drive down & then you'll be able to work out a price that won't leave them costing you too much overall. Feel free to send me a PM or you can give me a ring on 07821051311 if you want.
- waue1978
Re: 195/65/15's
Here are the pics of the worst wheel & trim. Hopefully it should show the bit of missing paint from the trim. All the other 3 are unmarked (apart from dirt). The tyre pictured is the one that seems to have lost a bit of air. The 4mm measurement was taken from the V bit in the middle.
Re: 195/65/15's
They look fine, will see you at the weekend, I'll let you know which day and time in next couple of days, can you pm me your address. Cheers ian
