DOORS LOCKING AND HAZARDS KEEP FLASHING
just been informed by a neighbour that my hazards are constantly flashing,ive been out and checked all doors and boot and still they flash.Igot in car via remote fob and as soon as i got in the doors were just locking and unlocking on there own,i started car and they locked but didnt unlock.I turned car of,got out went to lock which it did then it unlocked on its own and the hazards are still flashing.it was fine yesterday but we have had snow today,maybe a link i dont know,havent got time to take to garage im at work,any ideas
- jamjar1383
Re: DOORS LOCKING AND HAZARDS KEEP FLASHING
my rcl started playing up in the cold weather so i just lubed the door catches with some wd 40
d9 hdi 90 rapier estate
Does it have some form of alarm? SOunds worse than a stuck lock anyway
ye it sounds like an alarm fault to me as well
check all the fuses. But a tempoary solution to the flashing is probably disconnect the power.
hi guys thanks for your replies,hazards and car electrics are fine today,all the snow has gone and its not so cold,as it stands now im putting down to a cold issue but im not holding my breath,im going to spray all locks with wd40 and go from there,keep you guys posted,great forum.
i had an 1998 ford escort mark 5 that did that,
and when it rained the car use to start spluttering and missfiring when i was driving,
when its raining look under the bonnet and check for any water getting on wires ??
also are both inner wheel arch linings in place ? on the front ?
if one of the wheel sh*t covers is missing that could flick water up onto wires (well it did on my escort)
Where is the internal Alarm sensors on the 406s ?
or are they just trigerd off a door switch ?
Another thing ive found on somecars that Get the Poltergeist alarm syndrome is if your Voltage drops on Acar battery- it can Fire off the Alarm,
And in winter time Frost -Eats Batterys so it may be Worth getting a test done on the battery ,
my car has a genuine pug alarm fitted , have the receipt from peugeot from back when the car was new
mine has ultrasonics on the front pillows at the top near headlining
i dont like ultrasonics they cause false alarms with the slightest seatbelt movement in the car
my pug alarm was always false arming
thats why i fitted my own alarm last week which connects to the interior lights to activate it
voltage sencing alarms are the worst ever, as you said in cold winter the voltage drops often on a battery causing false alarms,lozz wrote:Another thing ive found on somecars that Get the Poltergeist alarm syndrome is if your Voltage drops on Acar battery- it can Fire off the Alarm,
Idont like Cars that Have the Alarms - wired in with the indicators,
Iwire up mine with Extra Leds which are inside, the car,
Ihad acar Took with a Top notch Alarm on it they overriden the Alarm with just a bit of Tin-foil,
they left me an Indicator lens
the 406 headlight is one unit so that would be a little tricky
plus ,,,,,,,, my new alarm works with the indicators and i know for sure they wont get to the wire because they are wired upto the back of the hazard light switch on the dashboard
and the controll module is under the glovebox
must be one of the microswitches in the door is forozen in the open position hence why the car thinks a door is open. I had the same problem with the switch closed so the door lights did not come on.
