OK, just a little correction - your internet does not come from Aberdeen; your internet point of presence will be in Ireland, else your internet would be
utterly sh*t - you'd have horrendously slow connections. All that's happening is that SpeedTest.net wants to use a server in Aberdeen as its test unit (it tests your internet connectivity by downloading data from and uploading data to this host, and using PING to measure the latency between your PC and that server). If there is a closer server on the map (and there are - Dublin, Dundalk, and Derry), click on one of those to run the test from there.
Guys - just a heads-up - the Mbit/sec rate isn't the whole story behind your internet performance - there are two other main factors - namely "contention ratio" and "latency".
Contention ratio is the number of users whose broadband lines go through the same Digital Subscriber Line Access Multiplexer (DSLAM) in the telephone exchange. The DSLAM takes in multiple DSL lines and uses multiplexing technology to pass the data for all of these lines through one single fibreoptic connection. This reduces the amount of cabling involved running between telephone exchanges/internet tier sites. The downside is that if the contention ratio is too high, you won't get much actual internet traffic. Typical contention ratios offered by ISPs are anywhere from 20:1 to 50:1 (meaning that there are between 20 and 50 DSL lines for every 1 DSLAM at the local exchange).
Latency is the amount of time taken for a packet of data to get from your PC to the DSLAM (actually, to any other host on the internet, but that's not something easily controllable - so the provider will only care about latency between your PC and the DSLAM). The more cabling between your home and the exchange, the higher the latency will be. People in rural areas using satellite or radio broadband (because they live too far from the exchange for landline-based DSL) will experience MUCH higher latency due to the greater distances involved - satellite internet will have a typical latency of 500 - 600ms, simply due to the distance between the satellite dish and the satellite, and the satellite and the earth station, and the earth station and the provider's internet hub. People on Sky Broadband aren't on satellite broadband though.
Anyway, here's my result:
I'm meant to be getting "up to" 16 Mbit/sec, but everyone knows (or should know) that never happens to anyone who doesn't live RIGHT next door to the exchange, with the cable running in a straight line between their master socket and the DSLAM.
