trip computer installation
- nick
hey folks, quick question. can anyone give me any pics or drawings they used to install a trip computer? iv read about the extra wise needed thats not shown im the hayes manual, but i dont even have one of those!
can anyone help?
p.s sorry about the state of the post.... im writing it on my phone!
cheers! Nick.
can anyone help?
cheers! Nick.
- niz406
- Admin <BR>Turbo God
I suppose if you have a newer version then its possible that the loom already has the connectors on it, if not go to the scrap yard, find a car that has one and take the loom
or alternatively you can research your wiring diagrams / schematics in your manual and the socket pins to locate the correct connections to the correct sensors etc..
Will take you a while but obviously worth it ! !
- niz406
I only like the front end of the 407 everything else is pants ! ! ! There is a kit for the 406 that turns the front end into a sort of 407, its the illusion kit from ecosse and its nice !
Gimme that new front end ! ! ! yay !
Use a different back end and skirts and its unique ! ! !
I would like the V6 engine if only it was more reliable, that with a twin turbo conversion would be sweet and good for 450 BHP ! ! w00t w00t !
Good thing that everyone has thier own taste in styling! The front is probly the main thing keeping me from ever owning one
Lights got kinda too round and that wide open round air intake *uhg* The rear lights I dun like either as they became too round like every other euro car lately... The 406 has a much "meaner" look which is why I had to buy it.
We're definitly on the same wavelength on the motor though!
406OCWelton wrote:Couldn't help it........... at first it was the picture of the 2 tone grey 406........and then later the monitor just got sprayed
- niz406
Dont get me wrong I think the 406 looks very agressive from the front and has some sweet lines, its just that the 407 has more in the sense of air intake through that mammoth grille...
Perfect for a stupidly large intercooler and other air intake devices ! ! ! The 406 is always let down by the hight of the rear end ! ! ! grrr, sills need to be parallel with the ground, well thats my opinuion anyway
- nick
i have the wiring loom behind the computer, but thats it. i didnt take the temp sensor.. silly me. the indicator stalk i got dosent let me push the button at the end, so i cant change the display and all it does is stay on the flashing - - - at the temp information. what i needed, and its been done before, is to find out what wires to short to act as the button at the end of the indicator stalk, and the special wire that runs directly from the ecu to the trip computer that iv read about online.
iv seen a couple of newsnet posts about it, but none give an exact how to. hoping some on on here can!
thanks,
nick
thanks,
nick
- niz406
nick,
See below:
http://peugeot.mainspot.net/wiring406/index.shtml#5
It would appear that the wire needed by the trip computer, its a black wire and is rated @ 15v from Pin32 of the ignition injection control unit...
Obviously I take it that the other wires are +12V, GND, +12V switched and possibly other sensor connections... How many Pins/wires are connected to the Trip Computer??
See below:
Hi Nick,
i was hoping to raise this topic at some stage. I've also been trying to get my trip computer to work, so far I can tell you the following:
I connected the display to the elec plug that's already there.
I changed the stalk to the one with the push button for the display.
I connected the temp sensor in the left door miror.
So far i also only have three flashing '---' on the display.
I found a reference somewhere that said you need to swop two wires on the ECU at that point I stopped as I wasn't keen on risking blowing the ECU because some guy on the other side of the planet can't remember if it was pin 52 or pin 53 or was it pin 54.
The Haynes manual is not much help as it doesn't show all the wiring for the display, it doesn't even show the wires to the temp sensor in the miror.
I know this doesn't help you much. Thought I'd just share my progress with you.
Ryan
Ryan
- niz406
Well I dont know, asking ppl to do naughty copyright stuff ! ! ! you could get us all into trouble
So go here and have a look at your diagram:
http://www.idea-central.co.uk/diagram.jpg
I've used my digi cam as do not own a scanner, its about 800+Kb and is quality image for you, or as best as I could in short time! its clear enough for your needs.
HTH
HTH
