Doing HDI cam belt, pics of cover bolts/ details
So Im going to change the cam belt pump and tensiners, can someone refresh my mind of where to bolts are that hold on the covers or maybe if there is a diagram in a Haynes manual that someone could scan and email me? Cheers
406 '01 110 GTX estate in white, the new tow car.
Re: Doing HDI cam belt, pics of cover bolts/ details
Pssst - Haynes 406 D9
- waue1978
- HDi don't believe it!
Have a look here Ian :Floodys wrote:So Im going to change the cam belt pump and tensiners, can someone refresh my mind of where to bolts are that hold on the covers or maybe if there is a diagram in a Haynes manual that someone could scan and email me? Cheers
viewtopic.php?f=10&t=8229&hilit=cambelt
Hopefully that should help.
Just a note about removal of the top cover.....
Leave the cover on until the top engine mounting is removed and lower the engine, this will give you more clearance to pull the cover off.
Fit the cover with the engine lowered, it will be much easier to fit.
All done! Cheers for advice!
