Drop Link rear suspension terminology?
Adsvisory on my MOT reads, "Near side rear upper suspension arm has slight play in the ball joint". Now I'm trying to find the right bit....
I think item 6 :arrowu: is the rear upper suspension arm?
I think items 5 :arrowu: are the drop links?
Can someone confirm, please?
Re: Drop Link rear suspension terminology?
I think I'll have to agree with you there, it seems the only non-droplink bit with a ball joint on it... Might be worth seeing how much of the other stuff you can replace while you're at it without spending too much cash, like bushes and the drop links?
Yes, item 5 in the second pic are the drop links. It might not look like them (perhaps Pug had something more robust in mind :roll: ) but there's dozens of pictures of the real thing on this here forum.
jasper5
Post by jasper5 »
The drop link is number 5, but I think number 6 is the advisory item.
Thanks for all your helpful replies gentlemen. 8)
I have some idea what I'm looking for now.....
keppler
Post by keppler »
Hi all,
Sorry for dragging up an old thread like this but I was under my car yesterday and found that two bushes in the rear suspension were shot. The worn bushes are number 16 and 17 in the diagram posted above.
Anyways my question is does anyone know what the exact name and part number of these two bushes so I can order them, or even better caould anyone direct me to a page that has the corresponding info for the numbers on the diagram?
Cheers lads.
plod
Post by plod »
As per elsewhere on the forum Doggy, purchase a new nut and bolt (which looks like 10,11 &77)for the horizontal link(upper arm) and simply cut the old one off
1999 D8.5 HDi GLX - Sold :(
jasper5
Post by jasper5 »
keppler wrote:Hi all,
Cheers lads.
16 is the rear trailing arm front bush.
17 is the rear lower suspension arm inner bush.
plod
Post by plod »
5131 99 Flexible Joint £12.77 (£10.64+vat)
5131 80 Flexible Joint £14.65 (£12.21+vat)
keppler
Post by keppler »
Cheers lads for all your info, the help is much appreciated. Good to know they dont cost an arm and a leg too, now off to the motor factors.
TheSongRemainsTheSame
Post by TheSongRemainsTheSame »
I'll steal this thread as well. Item #1 on the first picture, what is is called? And can I buy only the bushes? (79,72,13,12,78). Also while I'm changing everything back there - what is #15 first pic called?
Thanks in advance.
Land of the Free?
dummysock
Post by dummysock »
1 is a suspension arm E9 5175
plod
Post by plod »
TheSongRemainsTheSame wrote:I'll steal this thread as well. Item #1 on the first picture, what is is called? And can I buy only the bushes? (79,72,13,12,78). Also while I'm changing everything back there - what is #15 first pic called?
Thanks in advance.
01 5175 E9 Suspension Arm
79 5132 A8 Hexagonal Nut
72 6925 G9 Screw with Base
13 5169 03 Support Pin
12 5169 06 Washer
78 6936 65 Nut with Base
15 5131 78 Flexible Joint
