W reg 2000 110 HDI GTX
The auto-dimming mirror has never auto-dimmed since I've owned it - about 2 years. The green light comes on. Are there any know faults, tips, tests that might help me get it working ? Thanks This website helped me once before when I had the beeping handbrake problem.
auto-dimming mirror
Re: auto-dimming mirror
there have never been any topics about this (as far as i can remember)
there must be a fuse in the fusebox that is linked to the mirror
maybe have a look for it and check
Doesn't the light being on imply that the fuse is ok?
There's no common faults that I know of, perhaps you could try shining a torch in it to see if it dims. Try cleaning the light detector (next to the button) with some alcohol or similar, if nothing happens it's probably defunct.
Pfft, like I nobody else ever made a cock-up on here
the dimming takes a few seconds i find. park a car behind you put its lights on and compare the results with the mirror on and off.
steve_earwig wrote:Pfft, like I nobody else ever made a cock-up on here
