A/C question,
A/C question,
Is there an outside temp when the A/C won't operate? I tried mine today just to give it a run and it would not come on.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: A/C question,
air con shoulod work at any temp cos i use mine on hot, demists the windows faster
i think once the light stops coming on , on the switch, it may need re-gassing ?
mine certainly works even at -10
Re: A/C question,
I think... no, hold on...
Welly wrote:...the a/c will not run below 0deg C ambient - this is to protect the compressor.
Re: A/C question,
weird. mine certainly runs well below 0
well the light comes on on the switch so im presuming its on
Re: A/C question,
All modern-ish cars have a low temp cut off but some vary between -5deg, 0deg, +2 deg etc etc.. it's because the refrigerant oil cannot vaporise and circulate at these low temps so can damage the compressor. You don't really need the a/c function at these low temps as the outside air is very 'dry' anyway.
Re: A/C question,
cheers mate. i dont often use it below freezingso its good to know that for future reference
since my car is old it probably doesnt have the sensor
so i will make sure i dont use it at freezing temps ...
Re: A/C question,
The light comes on on the dash but i can't here the compressor cut in,i tried it later when the weather had warmed up a bit and bingo the compressor cut in so i reckon there must be a cold temp cut out.I suppose as the air from the vents with the A/C on is probably 6-7 deg what is the point if the outside air temp is less than that? I will keep an eye on it.
Re: A/C question,
Indeed, you cannot treat or condition air if it is out of the normal operating range - it's a bit like trying to heat air that's already coming in at 55 deg C. In the winter our outside air is very cold and very dry - most of the moisture normally held in the air has fallen onto the ground as dew, frost, damp whatever. In the summer the air can hold a lot of moisture and this is where air conditioning can be of great benefit in de-humidifying for greater comfort allowing the body to cool through vaporising perspiration.grasmere59 wrote:I suppose as the air from the vents with the A/C on is probably 6-7 deg what is the point if the outside air temp is less than that? I will keep an eye on it.
Re: A/C question,
Given the coolant running through the heater matrix is 90 degrees...Welly wrote:it's a bit like trying to heat air that's already coming in at 55 deg C.
Re: A/C question,
You know what I mean Mr Pedant
