What RPM in 1st ?
What RPM in 1st ?
just trying get sum ideas of what RPM you all use to set off in 1st gear ?
petrol or diesel ... please state with RPM you usually get to to set off in 1st ?
i usually get it to 1100 RPM ...
is that to low ?
whats the highest you could use before starting to knack the clutch up ..
sirwiggum
Re: What RPM in 1st ?
Post by sirwiggum »
On the HDi used to have to give it about 1500-2000 rpm to stop the feeling it was about to stall. Made it wheelspin in the wet and ice.
With the engine mount fixed it can take away without acceleration, have to get used to that again, so I would say you would be right, 1000-1100 rpm or so on level ground.
I hate hillstarts too :)
i' have my mobile mechanic coming round at the weekend give me a price for all mounts done //
which did you have done and how much was it ?
plod
Post by plod »
Strewth I don't even think about it, never mind look
Saying that, you can bet your bottom dollar i'll be doing it when I go back to work shortly - you what? don't call you shortly :lol:
1999 D8.5 HDi GLX - Sold :(
sirwiggum
Post by sirwiggum »
Worked out £100 a mount including the part. Those for uppers. Lower mount would be £££s as the driveshaft has to come out.
There are set rules for the correct engaging-the-clutch-in-first manoeuvre.........
Man:
Match the revs sympathetically to the load, incline and conditions without stalling and without slipping the clutch excessively and without creating an uncomfortable 'snatching' sensation as the drive train takes up the load.
Woman:
Approx 4000 revs.
robb
Post by robb »
Welly wrote:
Woman:
Approx 4000 revs.
or 6500 in snow :P :shock: Never really looked at the revs when setting off, as for hills I regularly have to stop on a 1 in 6 hill at some lights if Im in pole position the wheels spin like a bugger as the tarmac is well worn :shock:
6000 minimum. :supafrisk: more on petrols. 8)
More seriously, I never really look at revs either but tend to take up the drive a little before applying any 'loud' pedal.
