Multiplex
Re: Multiplex
FarmerPug wrote:wrong side, the sat nav one is on the right hand side, pull the carpet out of the way and you will see a blue multi connector and a relay connector. Im hoping the display bit fits the same plug as the MFD
cheers mate.
yup ive got the blue conector,
im tempted to go for a sat nav but that wouid mean getting another mfd :(
so iwill scratch that idea of the list
Re: Multiplex
Ive been lucky to get the kit, theres a drive, gps aeriel, bracket, relay, remote and then the display, and ill have to paint the surround to match. And if i was being fussy which will probably happen eventually the boot carpet it slightly different to have a flap for the sat nav.
Re: Multiplex
FarmerPug wrote:Ive been lucky to get the kit, theres a drive, gps aeriel, bracket, relay, remote and then the display, and ill have to paint the surround to match. And if i was being fussy which will probably happen eventually the boot carpet it slightly different to have a flap for the sat nav.
Good luck with it all mate,
hope its just all plug and play set up 8)
Re: Multiplex
i have the pp2000 if its not.
And ill have to repair this broken display, im hoping this device can fix it:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 500wt_1156
I might get a bit of work out of this fixing a few broken displays.
Re: Multiplex
FarmerPug wrote:i have the pp2000 if its not.
ah rite,
its just the ribbons that fail on them then causing dead pixels?
Re: Multiplex
i think its the ribbon which comes loose and looses lines. this heats the ribbon up and fixes the connections.
Re: Multiplex
Have you had one apart to see? Often these damn ribbons are just pushed in, it might just be a case of pulling it out, giving it a clean and shoving it back. Sometimes they have a collar around the connector you push down to release the ribbon but I've not seen many that are "bonded" in.
Re: Multiplex
the standard type b mfd has a just bonded in Mfd, ill need to see this new one to see what sort of connection its got.
Re: Multiplex
waue1978 wrote:From what I've seen it came in on Y plates over here which would be sometime after March 2001. Most things would be the same, but the main parts that I know are different are the steering wheel & airbag, stereo & obviously the stalk assembly which is the Comm2000 set up on the multiplex models. Seats are fine for both as mine came from a multiplex model & all of the airbag plugs were the same.
When I was looking round for mine, I test drove two Y-plate cars, neither of which had Com2000 stalks. I'm fairly sure I've seen the older set-up on a 51-plate, but never an 02 or later. (I recognise it varies a bit as you don't know how long a car remained unsold).
Re: Multiplex
I've seen both Comm2000 & normal set ups on Y plates, but never seen an X with Comm2000 or a 51 with standard set up. Is the multiplex really that bad or is it all just bad press? I quite like some of the extra features that didn't come on the pre-multiplex like the white dials & the auto-lights. When I was considering 307s, everything I read basically said they were unreliable heaps, but surely if they were that bad, there wouldn't be so many still going now?
Re: Multiplex
I think the main downfall of fully multiplex cars is the com2000, the indicators fail just as frequently as the non-multiplexed cars but it's much more expensive to fix.
Re: Multiplex
i dont think multiplexed cars are any more unreliable, they are just wired up differently perhaps more complex but look at how few 03 and 04 406s are on ebay getting broken for parts. Compared to other years
