ive just done an oil change but somehow ended up breaking what looks like a conection into the fuel filtre. can someone tell me this is please?
i started the engine and deisel went everywhere.
its situated above where the oil filtre is to the right on a HDI engine.
ive tried adding a picture but it wont let me, what format do the pictures have to be? so i can help a little more
thankyou
HELP meeeeeeee please
Re: HELP meeeeeeee please
Oops! Sounds like the fuel filter yes. New ones are over 50 quid from the stealer's, I don't think you can just buy the lid, or you could get one from the breakers but make sure you give if a good clean first. Btw there's two sorts - Bosch and Mahle, Bosch have a weird shaped seal on the top of the filter itself.
Most of us use www.photobucket.com
rippin stealers!!!!!!
thanks for your help
il check the scrappy
did you get one from ur local scrappy?
no i had to get a new one.
