Fuse Size For Heated Seats
Re: Fuse Size For Heated Seats
thank you dave
I guess I'll be swapping mine for 10s :shock:
well i was wrong. got the ecu now went to collect it today ..
there is 2 seperate power cable ..
1 for ecu and drivers seat and other for passanger seat alone.
also there is 2 heated seat single wires which both need a feed. the guy said it would be fine to solder together and run 1 feed .
but im thinking 4 fused feeds from battery will be better and safer ????
or should i run just 2 ?
Gary406 wrote:well i was wrong. got the ecu now went to collect it today ..
ithink you will be fine with one feed mate,
a couple of fused links on them wouid be good.
if iwas you tho id throw an isolator switch in for the seat motors if your having them on a direct feed from battery,
this is what id do because no doubt kids wouid mess with the seats if they suss out there permantly on, :|
steve_earwig wrote:Heated seats 15 amps both.
so i'll be ok running 1 power cable from battery for heated seats ?
there is 1 wire for each seat so i could run 2 but might just do 1 for thos since you said 15amp for both :?
I'm not saying that, the fuse diagram is.
ok ste. will check my haynes when i find it in the junk cupboard :lol:
my haynes is saying
front right seat 30A
front left seat 30A
from what ican see its 20amp but this info couid be for d9s so it couid difer.
edit correction :oops: :arrowd:
30A
Engine running relay, heated seats
Fuses
Rating
Supply
Application
F1
Shunt
Ignition + ve
Airbags and seat-belts pre-tensioning ECU, BSI
F2
5A
Air temperature sensor for passenger compartment, heater panel
F3
10A
Instrument panel, brake lights switch, stop lamps, cruise controlsafety switch (brakes), cruise control override switch (clutch), cruise control switch.
F4
5A
BSI
F5
Free
F6
10A
+battery
ignition + ve
Engine management control unit
F7
15A
Radio amplifier JBL, alarm siren
F8
10A
Interior lights, boot light, multifunction display, navigation ECU, control unit for memorising seat and mirror positions, alarm LED
F9
5A
BSI
F10
15A
Radio
F11
10A
Separate fuse
Left brake light, third brake light
F12
10A
Right brake light
F13
20A
+ battery
One touch window ECU (driver)
F14
30A
Rear window lift relay, one touch electric window control unit (front, passenger, coupe)
F15
20A
Pre wired supply to towbar
F16
20A
Control unit for memorising seat and mirror positions, electric driver's seat
F17
20A
Electric passenger's seat
F18
10A
Separate fuse
BSI. Illumination: switches, heater panel, display unit, automatic transmission selector
F19
10A
Rear fog lights and warning lights
F20
Free
F21
Free
F22
10A
Acc + ve
Rain sensor, map reading lamp, courtesy lights, window switches (coupe), glove box light, vanity mirror, mirrors control board, electrocrome interior mirror, control unit for memorising seat and mirror positions.
F23A
20A
Acc + ve
Cigar lighter
F23B
20A
+ battery
Cigar lighter
F24A
Acc + ve
free
F24B
+ battery
free
F25
20A
Acc + ve
Wiper stalk, headlamp wash relay, radio
F26
Free
F27
5A
Built-in system interface (BSI), rear window lift relay, key lock (automatic gearbox)
F28
Free
Built-in system interface (BSI 1)
Fuses
Rating
Supply
Application
A
20A
Battery + ve
Central locking, dead locking
B
20A
Windscreen wiper
C
40A
Heated rear screen, heated mirrors
D
15A
Rear wiper
E
30A
Electric front windows, sun roof
F
15A
Supply to the multiplexed VAN network
Engine interface unit with 34 fuses. (BM 34)
Fuses
Rating
Supply
Application
MF1
60A
+ Battery
BSI
MF2
20A/40A/60A
Engine cooling system
MF3
40A/60A
MF4
30A
MF8
50A
Fuse box BH28
MF9
60A
BSI
MF10
30A
Light switch supply, signaling
MF11
50A
ABS control unit
MF12
50A
Anty theft contact power supply
MF13
50A
MF15
ABS control unit
MF16
MF17
F5
15A
Horn
F6
15A
BSI
F7
10A
Termostats, fan relay
F14
10A
Headlight wash timer, diagnostic socket,
F18
Separate fuse
free
F19
free
F20
15A
Ignition + ve
Variable power steering ECU, variable suspension ECU
F21
10A
+ battery
Free
F22
Free
F23
10A
Ignition +ve
ABS control unit
F24
10A
Vehicle speed sensor, engine injection double relay, injection ECU, water in diesel sensor
F25
10A OR
15A
+ve after double relay
•Inertia switch, fuel pump (except ESJ94 engine)
•Fuel pump (ES9J4 engine)
F26
30A
Battery +
Engine injection double relay, engine fuel system, fuses 25 - 28 - 34 (BM34)
F27
30A
F28
10A
Free
F29
30A
+ battery
Pulsair relay
F30
10A
Front left fog lamp and warnign light on instrument panel
F31
10A
Front right fog lamp
F32
10A
Ignition + ve
Pressostat, coolant thermostat, eigine coolant level sensor, diagnostic socket, reversing lamps, fan relay, relay protection switch unit BCP3 (DW10 engine)
F33
10A
Automatic transmission ECU, selector lever position switch, shift-lock relay
F34
10A OR
15 A
- Oxygen sensor heating resistor, cruise control switch (XU engine)
- Engine fuel system, cruise control switch (DW engine)
fuse 17 in my book is for central locking :?
The above is D9s,
this is D8 :arrowd:
BF00 - 30 Fuse Box (In passenger compartment
Fuses
Rating
Supply
Application
F1
10A
Acc +
Cig. lighter
F1 A
Batt +ve
Cig. lighter
F2
15A
Ign. +ve
Engine coolant level sensor, water in fuel sensor, instrument panel warning lamps, trip computer, vehicle speed interface module
F3
15A
ABS control unit
F4
10A
Sidelamps +
Front left side light, right tail light.
F5
15A
Low beam +
Head lamp height corrector, headlamp wash pump relay coil, low beam warning lamp.
F6
Free
F7
20A
Batt + ve
Caravan socket
F8
Shunt
F9
5A
Side lamps+
Front right side light, left tail light
F10
30A
Batt + ve
Control unit for memory seats and mirrors
F11
One touch window control unit
F12
10A
Ign. + ve
Oil breather re-heat resistor, reversing lamps, A/C engine coolant temperature unit
F13
20A
Batt +
Electrically controlled passenger's seat.
F14
Electrically controlled driver's seat
F15
Alarm control unit, radio telephone, fan relay, engine temp. control unit, control unit for memory seat and mirrors
F16
20A
Batt +
Radio
F16 A
Acc +
Radio
F17
Free
F18
10A
Low beam
Rear fog lights
F19
Side lamps
Illumination: Instrument panel, switches
F20
30A
Low beam+
Left low beam
F21
+ ign. off
Compressor cut-off relay, air conditioning compressor, pressostat, fan relay, heating/ventilation controls
F22
Acc +
Rear wiper and rear wiper timer.
F23
10A
Low beam
Right low beam
F24
30A
Acc +
Windscreen wiper, wiper timer, rear screen heater time switch relay, wiper control
F25
5A
Batt +ve
Radio memory, compact disc player, analogue clock, instrument panel, trip computer, coded anti-start, front and rear courtesy lights
F26
30A
Hazard warning
F27
One touch electric window
F28
15A
Acc +
Trip computer, load warning lamp, rear view mirror control, one touch electric window, ECU for memory seat and mirrors, high frequency receiver for central locking, front window lift and sun roof relay, stop lamps, digital clock
F29
30A
Batt +ve
Front window lift and sun roof relay
F30
15A
Acc +
Front and rear courtesy lamp, vanity mirror, glove box light, "lights on buzer" relay, overspeeding buzzer, radio telephone transmitter-receiver.
BF01 - Fuse Box (Under Bonnet)
Fuses
Rating
Supply
Application
F1
5A/7.5A
Batt + ve
Injection control unit (petrol and diesel)
F2
Free
F3
25A
Acc +
ABS and traction control
F4
20A
Batt + ve
Engine running
F5
7.5A
Relay XUD11ATE
F6
Batt + ve
Free
F7
15A
Head light wash timer
F8
Free
F9
10A
Acc +
Oxygen sensor
F10
Fuel pump
F11
Free
F12
10A
+ after relay
2665
Left front foglamp
F13
Right front foglamp
F14
+ ve after
switch 002
Left head light
F15
Right head light
BMF2 - MAXI (Fuse box under bonnet)
Fuses
Rating
Supply
Application
MF1
50
Batt +ve
Steering lock
MF2
Steering lock, + after ignition switched off
MF3
Supply 30 fuse box
MF4
Lighting and signalling switch, + relay horns
MF5
ABS/traction control
MF6
20
1-Fan Unit
MF6
40
MF7
20
1-Fan Unit
MF7
40A
MF8
Heated rear screen
your list is correct with steve.
20amps for leccy seats..
think i'll do that then and use a 15amp for the heated seats ..
inline isolator switch is a good idea .. i might consider doing that ..
but with all the 3 wires connected direct to battery i think it will be fine as long as the heated seat switches are off.
dont the heated seats have a sensor in them?
so if no ones sat on the seats they wont heat up ...
dont know if thats true tho :?
thats a question i need to ask in a new post. as well as the seats cutting off if there on for 2 long.
