u should have called ova for a cuppa on the way backBailes1992 wrote:Yehh, did it by accident actually. Thought I'd go for a 5 minuite run, by the time I figured out what was causing my wobbly wheel I hit Pont Abrahamjamjar1383 wrote:did u come up my way?? ie past llanelli???Bailes1992 wrote:Tonight I took Betsy for a little blast down the M4. 30 mile each way, right to the end of the M4 and back, did 70ish miles by the time I got home.
Bar the little steering shakes she was lovely sat at 65-70mph.
I'm 99% sure my steering shuiddering is a CV joint, if your just cruising and not steering you don't get any vibrations at all. As soon as you accelerate or decelerate you get vibrations and if your turning at the same time then they get worse. Nothing to worry about then
