type d8 or d9
Re: type d8 or d9
I think that's generally agreed. Shame about the MUX :(
Re: type d8 or d9
Pre-MUX D9 is the solution there! Anyone want to buy a pre-MUX D9 saloon? Still got one for sale ... needs a little bit of bodywork.
Re: type d8 or d9
If it's a D9 it has a BSI and if it has a BSI it's multiplex. See? I can be more opinionated here than on the coupé club :mrgreen:
Re: type d8 or d9
But if a D9 is multiplex does that mean it has a com 2000 or
was that added later ?
Re: type d8 or d9
Put it this way, everything I read says they went multiplex in 2002. Which is of course bollocks - I guess this refers to the com2000 which was added July 2001 and this is definitely multiplex. Before that they had a BSI and I can't think of any reason for the car's systems to have a central processing unit, unless it was in some way digital - i.e. multiplex. Even Haynes' vague and almost totally useless wiring diagrams feature the BSI and they don't cover com2000-equipped cars. Yet there it is, item 16 on almost every damn diagram, often featuring the magic words "See diagram 7 Multiplex VAN"
So, what do you think? :?
I wonder if this apples to the D8.5 :?
Re: type d8 or d9
I'm sure I've read that all 406s are multiplexed to some degree. The D9s pre-COM2000 are similarly wired to the D8s, but Peugeot apparently went a little bit nuts with the old multiplexors when they decided COM2000 would be a great thing to put in them.
Re: type d8 or d9
Well io know mine has got a bsi and no com 2000 so that
confirms what you say steve , got to love the french the
way they put cars together :roll:
lecky4
Re: type d8 or d9
Post by lecky4 »
A member of the coup forum posted this link http://www.peugeot406coupe.com/phpBB3/v ... 35&t=17970 to show thw difference between a D8 & D9. Hope it helps make it a little easier.
It may only be 12V but it's the amphere that kills you!
3Ltr V6 ES9J4S D8
plod
Re: type d8 or d9
Post by plod »
Check this T reg out
8.5 or repaired on the cheap?
http://cgi.ebay.co.uk/1999-PEUGEOT-406- ... 3a640bf4f1
1999 D8.5 HDi GLX - Sold :(
Re: type d8 or d9
plod wrote:Check this T reg out
I'll go along with that. Also, is it the angle of the photo or does that bonnet look a bit iffy over the nearside headlamp?
plod
Re: type d8 or d9
Post by plod »
Well spotted
OdinEidolon
Re: type d8 or d9
Post by OdinEidolon »
I spotted a "D9" writing on my 2001 car. Wonder if <1999 cars have D8 written where I have D9?
This is the place: you know you have a small almost not visible "VDO" writing on the left speedo (rev counter), at the bottom? Look at the same place of the right speedo: there I have "D9". Is this common?
Re: type d8 or d9
I had that on my 1999 saloon - D9, written in glossy black text on a matt black background, so you don't see it unless you look closely.
I wonder if that's there on HDis with white dials?
OdinEidolon
Re: type d8 or d9
highlander wrote:I had that on my 1999 saloon - D9, written in glossy black text on a matt black background, so you don't see it unless you look closely.
Never noticed it for sure. Is it there on D8s?
Re: type d8 or d9
Would normally say D9 15m or D9 16m - depending on how high the speedo goes. 15m = 150mph, 16m = 160mph. Never noticed anything like it on a D8, but the clocks on D8s were made by a different manufacturer. If memory serves, D8s are Sagem & D9s are VDO Dayton.
