My car was driving absolutely fine apart from a loss of coolant, it was obvious that the car was pressurising the cooling system, as it was forcing coolant out of the expansion tank. As you may know im in the process of stripping the car myself as a garage wanted £900 to do a Hg, rad, cambelt, water pump, oil and filter change. I said no thanks It may be steam coming out the exhaust.. can you do a sniff test on it? only takes 5 mins to do, and will tell you one way or the other. like your car i used to go upto 90deg in traffic and it would cool straight back down when back upto speed.
Col
driven carefully i did 3000 miles with my head gasket going, losing coolant but no oil water mixing. towards the end it started getting warm in traffic so had to do it in the end, that was on my old 2.1td, which went on to do another 75K miles trouble free in 12 months
98, Executive turbo estate in aluminum silver. The stealth wagon! Now departed, New project Xsara VTR-8 in progress, Next Project, 406 D8 / JAP. So will be looking for a 406 again when the xsara is done!
not sure to be honest i did my own, but id imagine you wouldnt get much change from about £400 inc parts
As said mate try some k-seal first, there is a few 'miracle cure' products available now, There was one in my local motor factors called steel seal (I think) thats supposed to seal leaking head gaskets, its £30 a bottle tho
The shop said the feedback from it is good and that it works, they said a guy bought some for his Vectra, put it in outside the shop and it sorted it, Can't see it myself
A sniff test is a pippet thing with a chemical in thats yellow to start with and if it detects exhaust gasses in the expansion tank it turns the chemical blue
gary does the heater blow hot air when the engine's warm with out any rev's, ie idle???
if it needs rev's to get it to blow hot then yes its f*cked. if not u should get away with k seal.
the white smoke u speak of is probs water in getting in to the cyclinders.
french cars seem to go this way especilay small renualts and pugs. ive done quite a few in that last year
d9 hdi 90 rapier estate
jamjar1383 wrote:gary does the heater blow hot air when the engine's warm with out any rev's, ie idle???
car is normal mate. heaters get very hot. it idles perfect. i changed my coolant sensors last week and stupid me did it after a long journey plus i never removed the coolant lid to de-compress the system so when i took sensor off coolant shot 15 foot in the air and all over me
so i'm thinking the drop in coolant could be from me not topping it up enough. and the white smoke could well be the veggie oil.
just spoke to guy at local factors. he can do me a bottle of K-seal for £10. its worth a try.. plus i'm gonna fill tank up with diesel soon. get rid of veg oil to see if thats the cause of the white smoke ..
My cars been on veg oil since i bought it in January,and ive not had any white smoke. I have read that running your car on veg can expose weak spots in the car though.. (whatever that means!!??).. i would doubt that is whats causing the white smoke on your car. Good luck!
