Looking to get some decent rear anti roll bar stabiliser links, looking on eurocarparts lemforder one's http://www.eurocarparts.com/anti-roll-bar-components
look all the same but are priced different am i missing something and what would you recommend
cheers
ps: what would i be looking at to get them done been quoted £90 for supply and fit
£90 is that for one side or both,
id presume theyl be changing the top link most probs theyl use qh ones if so so there around £18 each.
the rest will be labour charge,
if its just one side theyve quoted for ithink theyd be having a Giraffe
Gary406 wrote:£54 a side what the hell they changing ?
do it yourself it is all easy.
which ones were you looking at on euro car parts ?
this
or this
I presumed its the bottom pic but now i dont know. i phoned a motor factor and said i needed links
and they dint ask me top or bottom they just gave me a price
lozz wrote:£90 is that for one side or both,
steve_earwig wrote:This might take some of the mystery out of it:
problem is they didnt show me so im not sure which one's they were on about
but i might go to another place and get them to show me and sort something else out
Gary406 wrote:who ever told you you needed the stabilizer links chaging you need to ask them which ones.
there are 2 on the back. as in the piccys.
plastic one is the lower droplink and sits vertical
metal one is the upper toplink and sits horizontal
both are cheap and should not cost £54 a side
got knocking on the rear just popped in there to see what it was
they also said about the exhaust hitting the towbar but that was with
a bit of force but couldn't do anything about that
lozz wrote:where are you located mate,
if your local-ish to me iwill fit them for ya
im in weston-super-mare
thats millions of miles away from me ..sorry if you were abit more nearer iwouid of changed them for ya,
tip : buy the parts yourself and go in kwik fit and ask one of the lads if they want to do a foriener
there's a bloke at work that done the brakes on 1 of my cars before might ask him just need to find what i need first
and get quality parts as ive read on here about cheapies going within a year
