front end woe
front end woe
Hi guys got a rattling clunking noise on the drivers side front end when going over bumps gonna get underneath tomorrow what shall I check out thanks in advance .....Rob
Re: front end woe
My guess is drop linksrobb wrote:Hi guys got a rattling clunking noise on the drivers side front end when going over bumps gonna get underneath tomorrow what shall I check out thanks in advance .....Rob
Re: front end woe
Thanks Lozz been reading the threads on those sounds like first port of call
Re: front end woe
Mine sounded like it was falling to bits over the slightest bump ipulled and tugged on the droplinksrobb wrote:Thanks Lozz been reading the threads on those sounds like first port of call
and they looked fine they looked like theyd been on a while so ichanged them all the noise disapeared
sometimes the droplinks look ok when the car is jacked up but when the weights on them theyre loose,
icheck them with the wheel on and car on the ground now and just pull on the links if theres play there off and binned,
Re: front end woe
yep i also agree DROPLINKS very very easy to change. 2 bolts is all (an angle grinder may be required to get the old ones off) they seize like sh*t to a blanket
i get mine from ebay , the ones for £10 odd for 2. never had any problems with these ones.
but my current front droplinks have been on now 11 months and are still going strong (the ones from ebay)
some say dont get rear links from ebay because they dont last long, but my fronts are from ebay .
Re: front end woe
Thanks for the advice Lozz and Gary its only just started clunking in the last 2 days but its really annoying
ps do the bolts come supplied with the links?
Re: front end woe
dont worry about it for now mate.
get yourself 2 new ones from ebay only £10 odd (£10.39 i think)
when you get the new part you will see were they go on the car (if you dont know were they are now)
it really is as easy as taking 2 bolts out knocking the link bar out and bolting new 1 in.
Re: front end woe
okey dokey guys
Re: front end woe
they get worse and worse if its fubard droplinks,robb wrote:Thanks for the advice Lozz and Gary its only just started clunking in the last 2 days but its really annoyingps do the bolts come supplied with the links?
they start of with a creak then a click then rattle like feck then clunk.
Ialways Go for the QH branded ones or theres a cheaper brand thats good too Firstline or something like that the brand is,
Ive Tried Ebay ones on Ford cars and They Didnt last a month Total garbage,
Idont know what the 406 ebay ones are like
Re: front end woe
robb yes the new links will come with 4 new bolts
Re: front end woe
nice one
Re: front end woe
just an update it was the droplinks both changed now running ok with no rattly clunk.
Re: front end woe
Excellent news mate,
glad you got sorted
glad you got sorted
Re: front end woe
had the same with mine but on the nearside, but didn't do it as badly when turning?
I replaced both, which was good advice - problem gone
Glad to see you got it fixed
Returned from the dark side and back to a 406
2.0 16v GTX HPi Saloon - China Blue Pearlescent 106k - One Owner from New - Full dealer History
Re: front end woe
Thanks guys the noise was irritating me to the point of distraction
