I got this wired fm modulator:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1005wt_648
the aeriel plugs dont match the peugeot one at the back which im sure you know how it is, i cant really describe it well, its like a plug that goes over the socket in the radio.
Anyhow what sort of adaptor do i need for the aeriel to put the normal long plug into one of these odd ones, and one for the other end?
Aeriel Plugs
Re: Hairyhole Plugs
I can't see anything in that pic, is this what you're on about? viewtopic.php?f=4&t=13624&p=125131&hili ... or#p125131
Re: Aeriel Plugs
good stuff,
so i can explain it better
the device i got has 2 aeriel wires the one that looks like a f*cked up rca lead, and a socket to accept the f*cked up rca lead.
But the peugeot has the press stud, easy enough to get around the connection of the modulator into the radio with the converter but how do i get the press stud plug to fit down into the modulator which accepts a f*cked up rca lead.
Re: Aeiouriel Plugs
I guess you'll need something like http://www.amazon.co.uk/ADAPTER-CABLE-a ... 283&sr=8-4
Re: Aeriel Plugs
problem solved thanks steve
Re: Aeriel Plugs
Actually ive realised there is more to it, that amazon part will work for the fm transmitter to the radio, but then the transmitter itself requires a f*cked up rca lead into it from the car aeriel which is a stud plug.
So i need a stud plug into f*cked up rca adaptor.
- lozz
Re: Aeriel Plugs
see if you can find a pic mateFarmerPug wrote:Actually ive realised there is more to it, that amazon part will work for the fm transmitter to the radio, but then the transmitter itself requires a f*cked up rca lead into it from the car aeriel which is a stud plug.
ive got loads of plugs and differnt stuff irip out of taxis and ex fleet cars,
ive got a rca type connector in my junk box with a airel type end on it if youve got apic iwill double check and see if ican find you one
