the car was recovered and as it was overheating the clyinder head was removed , skimmed,pressure tested and new gasket set fitted ,along with new timing belt
now the bad news
i thought nightmare , then got my code reader out to see if there were any possible ecu faults , they were 25 faults , but i assume the garge had been unpluging sensors etc which may have stored on the ecu, anyway i cleared every code and started the engine , and then re checked for any codes , only fault code i have is a heater relay fault , but i carnt see this causeing the main issiuse that ill explain ,
im not machanic , but i thought id check and bleed the water and found top rad hose hot and bottom cold , removed thermostat , jet washed heater matix and front radiator and still same happernd , it over heated ,,next i removed the cambelt and removed water pump to find the inpeller had come lose
now the bad issiuse the engine will start first crank off the key and idiol fine on 4 clyinders as i rise the rpm to 2000rpm everything seems fine , but soon as i rev to 2200rpm the maxium the engine will rev , i hear a suddern rattle(like a injector rattle ) and and engine will drop on to 3clyinders (like if u unplug a injector ) then come back onto 4clyinders and idiol fine again
ive removed the injectors this morning , and checked the compression which all seem very good for a 168,000 engine but i carnt check these above 2200rpm with engine cranking , i think this maybe a knackerd injector as when it missis and drops onto 3clyinder i get a strong smell of eye stinging fumes
due to having no ecu fault codes i wont assume its the accelerator electronic unit/common rail pressure sender/or main pump as my scanner shows everything is fine , ive also done a video below of the scanner and what the engine dose ,
http://tinypic.com/r/112g80k/7
