Indicators
Indicators
simple question - on a 2000 D9 LX should there be a clicking when the indicators are going? only thing that bugs me about the car!
2000 D9 1.8 LX Saloon - 42k
Re: Indicators
Not sure about 2000 cars, later ones have a very quiet, electronically generated, 'click' that comes from a tiny speaker in the Com2000 stalk assembly. (You can't hear them either).
- highlander
- PowerFlow Shill
Re: Indicators
My 1999 Saloon (early pre-COM2000 D9) does it. It's like a relay clicking on and off.
The 2002 Coupe (COM2000-equipped) does it too, but as Doggy mentioned, it's a softer sound. With the radio on, you can sometimes fail to hear it.
Both my old Mk. 1 Renault Clios did it too. I think it's actually very common.
- waue1978
- HDi don't believe it!
Re: Indicators
Learn to live with it - there's worse than that around. The first Iveco Cargos used to have an annoying beep that accompanied the indicators.
Re: Indicators
mine doesn't actually click which i why i asked - the lack of a noise is actually more irritating!
Re: Indicators
defo get a click on my D9 2001 LX. can only hear it if the music turned down though but its definately a good solid click!!!
Re: Indicators
Does anyone know where the pre-Com2000 'click' comes from - is it a little speaker or something the OP can check easily?
Re: Indicators
my 2000 estate does the sound, i don't wanna push my knowledge about it but, i guess the sound is produced from the speaker that does the bleeps if you miss the key plugged in on the dashboard, when the motor is off, and when you forget to turn off the headlights when the motor is off, but it can be a relay, one of these 2 things must be it, and i think is easily something to check.dogslife wrote:Does anyone know where the pre-Com2000 'click' comes from - is it a little speaker or something the OP can check easily?
2000/May 406 Estate 2.0 HDI 110bhp DW10ATED now with 205k km & now with cruise control & now remaped @ 134bhp
Re: Indicators
The Eurocargo (2004) I drive has a very annoying beep to itwaue1978 wrote:Learn to live with it - there's worse than that around. The first Iveco Cargos used to have an annoying beep that accompanied the indicators.
1999 D8.5 HDi GLX - Sold
Bring back my 406
Re: Indicators
if they're combined then it would explain why it doesn't beep when you leave the lights on either. any idea which relay?RayneR wrote:my 2000 estate does the sound, i don't wanna push my knowledge about it but, i guess the sound is produced from the speaker that does the bleeps if you miss the key plugged in on the dashboard, when the motor is off, and when you forget to turn off the headlights when the motor is off, but it can be a relay, one of these 2 things must be it, and i think is easily something to check.dogslife wrote:Does anyone know where the pre-Com2000 'click' comes from - is it a little speaker or something the OP can check easily?
Re: Indicators
the new c4 if i recall the brochure correctly allows you to personalise the sounds, this being one of them.
Re: Indicators
Can you explain more about that ?FarmerPug wrote:the new c4 if i recall the brochure correctly allows you to personalise the sounds, this being one of them.
Re: Indicators
The warning sounds, like door open, indicators, etc the menu allows you to choose a number of different polyphonic sounds for them.
Although i doubt the indicators one is going to allow you to have something like the nokia tune, its probably a choice of different indicator noises.
Still nice to have that level of choice.
Re: Indicators
where can i find " this " menu ? i didn't understand it right, What i must have to go to this menu ?FarmerPug wrote:The warning sounds, like door open, indicators, etc the menu allows you to choose a number of different polyphonic sounds for them.
Re: Indicators
its only in the new c4, i read it in the brochure, probably for the top end cars.
and the c4 hasnt been released yet, or at least not many are about yet.
