Cleaned my MAF now Check Engine Light on and no power
Foghorn Leghorn
Post by Foghorn Leghorn »
Give this place a buzz http://www.pugbitz.com
i used them for the resistor I needed, the guy who runs it is en ex Peugeot mech and seems to know his stuff.
All he should need is the part number for the fan and he'll tell you if hes got one or not.
Edit: doh!! didnt read the bit about new only...
Doddle to fit, shouldn't need to remove bumper, just the grill
Fog
Got me a new Cooling Fan from Eurocarparts £107.00 inc VAT (puggy's wanted £129.00 :P )
It is an OE fan and it's even in a Peugeot Box!
The fan will be fitted on Mon/Tues and the current draw tested (I worked out it should be about 29 amps not 48 like the old one).
The ECU is clear of any codes now so the new fan should keep all the voltages in check.
Lokking forward to getting it back, then it will be treated to an Oil service by me :shock:
