Noise coming from rear end
Good evening guys, im after some advice. I have had this grinding noise coming from the rear of my car for quite some time,mainly when i turn right, i have taken the wheels off to investigate and it seems like the disc guard behind the disc is rubbing the inside of the disc when cornering. I changed the rear drop links and the noise stopped for a while but now it is back. Im not sure what is causing the disc plate to float into the inside of the disc? i bend it out the way but it will work its way back.
I replaced two of my rear tyres shortly after the rear drop links and one month later they were on the wire on the inside,(i should have got it aligned straight away) now i have got the 4 wheels aligned, but im not convinced.
Recently i have noticed (when i took all the interior out of my car to do a run to the tip) there is quite a loud bearin ish type rowing noise coming from the back, do you think knackerd bearings could be the cause of this? i have jacked the wheels up and spun, shook them and they seem fine? I am going to change the two rear bearings this weekend to see if this helps. Do you know if this is an easy job? are they pressed, or is it a bolt in jobby?
Car is a 1999 406 esec estate. 2.2 HDI.
Any help appreciated
406 2.2 HDI executive Estate
Re: Noise coming from rear end
Before you go spending a small fortune
The back plates like to rust and can rub on the disks, especially under cornering. Also check the shoes for missing springs...
hi steve, to be honest the back plates are not that rusty, they are in pretty good nick, i have come so close to getting the angle grinder out and cutting them off, this noise is driving me crazy.
I have had the discs off and checked/cleaned the drums out, the shoes are fine e.t.c but i havent checked for missing springs, i will have to do that.
Are the bearings a bolt in replacement?
Bearings are not available on their own, and you have buy the hub instead
My mechanic mate did both my rears in 40 mins
1999 D8.5 HDi GLX - Sold
Bring back my 406
Cheers Plod, doesnt sound like a big job then, did he do them at a garage or at home (did the old ones need pressing out) are these pug only part? or can you get them from a local factors? any idea how much they were?
Does anyone know how many ABS Teeth there are on my car (1999 2.2HDI 406 exec estate) 29 or 48 teeth
Thanks for your info guys much appreciated
- Captain Jack
Didn't think they made 2.2HDIs in 1999....
- highlander
- PowerFlow Shill
From what I know, the DW12 TED4 engine made its debut in 2000, being featured in the C5 and 607, and it made it into the 406 range from 2001
I know they made them without com2000 so they must have come in before July 2001
They'll be 48 tooth anyway.
My bad sorry guys she is 2001, sorry for the confusion.
Will it still be a 48 tooth?
Hope this doesn't confuse things still further, but a while back I was convinced I had a rear wheel bearing problem, but it turned out to be an oddly shaped rear tyre - looked perfectly OK, but when you ran your hand over it there were detectable 'lumps' every few inches around the circumference.
I know it sounds unlikely, but I recommend swapping both rear wheels in turn for the spare and diriving it for a few miles to check. (At least it's cheap)!
To be honest, i dont think it is the bearings either, because when i jack it up, there is no play, and the wheels spin lovely, but there is this constant drone coming from the rear end, and as i do mainly motorway miles, its really annoying me. The car needs two new rear tyres anyway, so i am going to replace them before i do the bearings (but i dont think its tyres either, as i have swapped front-back before).
I just thought maybe a worn bearing might also be contributing to my rubbing disc noise (play in rear wheel even tho i cannot feel it)when i corner, which is also slowly driving me insane.
Do you think there could be any bushes/bearings gone in the rear axle which is causing the disc cover to hit the inside of my disc?
Evening guys, i thought id let you know my findings from tonight. I took the discs off and found nothing wrong with shoes e.t.c everything seemed to be in spot on condition. When i spun the passenger side rear wheel bearing by hand it was "juddery". I removed the cap to inspect the bearing and you could blatently see that that was the problem, it was try as a bone and it looked rusty...not good. I really didnt think it was the bearing, because when the wheel was on, there was no play side to side/top to bottom e.t.c...but i was prooved wrong.
Still not sure why the inside of the disc guard rubs my disc...i think im going to end up cutting it off lol!
Oh and dogslife..you were sopt on..it was the 48 tooth
Thanks again guys
Thanks again guys
Perhaps the whole lot has enough movement (with the weight on) for the disk to touch the backplate
Kind of you to say so, but I think that was young master Earwig.....Peter86 wrote:Oh and dogslife..you were sopt on..it was the 48 tooth![]()
Glad you've tracked it down. I suggest swapping the hub first before resorting to more radical surgery.
